DeepStream Version - 7.0
Docker Image - nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
GPU - RTX A6000
NVIDIA GPU Driver - 535.183.01
Upon trying to implement Multi-object Tracker using the following code inside main()
tracker = Gst.ElementFactory.make("nvtracker", "object-tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
some other code
pipeline.add(tracker)
some other code
pgie.link(tracker)
some other code
tracker_source_pad = tracker.get_static_pad("src")
if not tracker_source_pad:
sys.stderr.write(" Unable to get tracker src pad \n")
else:
if not disable_probe:
tracker_source_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_probe)
along with the following probing function -
def tracker_probe(pad, info):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer")
return Gst.PadProbeReturn.OK
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame:
l_obj = frame_meta.obj_meta_list
while l_obj:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
print('----------------------------------------------\n')
print(f"Object ID: {obj_meta.object_id}, Class ID: {obj_meta.class_id}, Confidence: {obj_meta.confidence}")
l_obj = l_obj.next
l_frame = l_frame.next
I’m getting the following error -
0:00:02.618304991 3572838 0x55f42ea86c80 DEBUG nvtracker gstnvtracker.cpp:211:gst_nv_tracker_start:<object-tracker> gstnvtracker: numStreams set as 0...
0:00:02.618342151 3572838 0x55f42ea86c80 DEBUG nvtracker gstnvtracker.cpp:222:gst_nv_tracker_start:<object-tracker> gstnvtracker: batchSize set as 1...
gstnvtracker: Loading low-level lib at (null)
gstnvtracker: Failed to load NvMOT_Init
gstnvtracker: Failed to initilaize low level lib.
0:00:02.618387216 3572838 0x55f42ea86c80 ERROR nvtracker gstnvtracker.cpp:261:gst_nv_tracker_start: gstnvtracker: Failed to initialize trackerIface
What could be the issue here?
Following is the tracker config section from my configuration file -
[tracker]
tracker-width=1920
tracker-height=1080
gpu-id=0
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
tracking-id-reset-mode=3
I have verified that the files libnvds_nvmultiobjecttracker.so
and config_tracker_NvDCF_accuracy.yml
are available and have sufficient read permissions on the server.
