Does the tracker do anything when the pgie interval is 0? Should it be removed from the pipleline or is it actually working?
Tracker is used to generate a track id, pgie cannot do this even interval is 0.
Ok so if you want to identify unique objects, the tracker is still helpful even when the pgie interval is 0.
Exactly, pls let me know if any issue you met?
All good. I’m just testing different configurations and wondered if I am supposed to remove the tracker component when pgie interval is 0. All good and thankyou for your help…
