Tracking ID duplicated over separate streams
• Hardware Platform: Nvidia Jetson AGX ORIN
• DeepStream Version: Deepstream 6.1.1
• JetPack Version : 5.0.2
**• TensorRT Version 8.4.1 **
**• Deepstream and all dependencies are running inside docker container built following this approach Link
I am running a Deepstream pipeline with 2 RTSP input streams, nvinfer plugin for object detection, nvtracker (NvDCF) and RTSP sink.
We are noticing that certain tracking IDs are repeated in both camera streams even though they have different angles, and locating different target objects.
What could explain this behaviour?
Can you have a try with: useUniqueID: 1
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvtracker.html
Thank you for quick reply!
Primarily this fixes my issue programmatically.
With the display however I did notice few times repetitions of certain tracks IDs. When I print out the object_meta attributes I assert there is uniqueness per stream.
Could it be that whatever plugin responsable for mapping the ID to [0,1,…] is miscalculating the IDs?
Kais
Can you print the obj_meta->object_id? Share us the log if you see any miscalculation.
