Tracking using Vision Works (GPU) on Jetson TX1
Hi!
I’m wondering if there’s any tracking tutorials using Vision works (GPU) for tracking?
I really need a fast tracker for face tracking.
Thank you!
You can check VisionWorks document directly.
Package Name      : libvisionworks
Installed location: /usr/lib
Description       : Main package with pre-built shared libraries.
________________________________________________________________________________
Package Name      : libvisionworks-dev
Installed location: /usr/include
                    /usr/lib
                    /usr/lib/pkgconfig
                    /usr/share/visionworks/cmake
Description       : Development package with headers, supplementary CMake and
                    package config files.
Package Name      : libvisionworks-samples
Installed location: /usr/share/visionworks/sources
Description       : Source code for samples, demos, and NVXIO.
[b]Package Name      : libvisionworks-docs
Installed location: /usr/share/visionworks/docs
Description       : Documentation package for this release of VisionWorks.[/b]
I found it under /usr/share/visionworks_tracking/sources/samples/object_tracker
Thank you!
