I’m working on a project to train an agent that takes a 4D tensor (RGB + depth sensor) as the observation. And I want to add the rl_games CNN block + to the MLP layers. But when I try to add the CNN configuration, I’m getting exceptions. I see in the vec_task file the osb_buff is a flat tensor of N-elements, so I tried to change the size of the osb_buffer to size(width, high, channels, n_envs) but nothing is working. Any ideas?
Here is the network block from my TaskPPO.yaml file:
network:
separate: False
space:
continuous:
mu_activation: None
sigma_activation: None
mu_init:
sigma_init:
val: 0
fixed_sigma: True
cnn:
type: conv2d
activation: relu
initializer:
regularizer:
convs:
- filters: 32
kernel_size: 8
strides: 4
padding: 0
- filters: 64
kernel_size: 4
strides: 2
padding: 0
- filters: 128
kernel_size: 3
strides: 1
padding: 0
mlp:
units: [256, 128, 64]
activation: relu
d2rl: False
initializer:
regularizer:
this is the change I tried on the vec_task.py
if enable_camera_sensors:
img_width = config["env"]["imgWidth"]
img_height = config["env"]["imgHeight"]
img_grayscale = config["env"]["grayScale"]
img_chs = 2 if img_grayscale else 4 # GD or RGBD
self.obs_space = spaces.Box(low=0.0, high=1.0, shape=(img_width, img_height, img_chs), dtype=np.float32)
else:
self.obs_space = spaces.Box(np.ones(self.num_obs) * -np.Inf, np.ones(self.num_obs) * np.Inf)
And this is the error I’m getting when I try to run the training (for n_envs=64):
RuntimeError: Expected 4-dimensional input for 4-dimensional weight [32, 4, 8, 8], but got 2-dimensional input of size [64, 16384] instead
