Train ngc api key setup issuein TESLA V100
2022-04-29 06:32:38,795 [INFO] root: Registry: ['nvcr.io']
  File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 677, in urlopen
    chunked=chunked,
  File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 392, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.6/http/client.py", line 1281, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1327, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1276, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1042, in _send_output
    self.send(msg)
  File "/usr/lib/python3.6/http/client.py", line 980, in send
    self.connect()
  File "/usr/local/lib/python3.6/dist-packages/docker/transport/unixconn.py", line 43, in connect
    sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 727, in urlopen
    method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
  File "/usr/local/lib/python3.6/dist-packages/urllib3/util/retry.py", line 403, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.6/dist-packages/urllib3/packages/six.py", line 734, in reraise
    raise value.with_traceback(tb)
    chunked=chunked,
    self.send(msg)
    self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 205, in _retrieve_server_version
    return self.version(api_version=False)["ApiVersion"]
  File "/usr/local/lib/python3.6/dist-packages/docker/api/daemon.py", line 181, in version
    return self._result(self._get(url), json=True)
  File "/usr/local/lib/python3.6/dist-packages/docker/utils/decorators.py", line 46, in inner
    return f(self, *args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 228, in _get
    return self.get(url, **self._set_request_timeout(kwargs))
  File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 543, in get
    return self.request('GET', url, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 530, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 643, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 498, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "/usr/local/bin/tao", line 8, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.6/dist-packages/tlt/entrypoint/entrypoint.py", line 115, in main
    args[1:]
  File "/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py", line 297, in launch_command
    docker_handler = self.handler_map[
  File "/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py", line 152, in handler_map
    docker_mount_file=os.getenv("LAUNCHER_MOUNTS", DOCKER_MOUNT_FILE)
  File "/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py", line 62, in __init__
    self._docker_client = docker.from_env()
  File "/usr/local/lib/python3.6/dist-packages/docker/client.py", line 85, in from_env
    timeout=timeout, version=version, **kwargs_from_env(**kwargs)
  File "/usr/local/lib/python3.6/dist-packages/docker/client.py", line 40, in __init__
    self.api = APIClient(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 188, in __init__
    self._version = self._retrieve_server_version()
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 213, in _retrieve_server_version
    'Error while fetching server API version: {0}'.format(e)
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
I am afraid you were triggering tao docker based on aonther docker.
In this case, please
add -v /var/run/docker.sock:/var/run/docker.sock
Reference: Run TLT inside docker - #8 by Morganh
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
