hi everyone, i am trying to train ssd-mobilnet object detector with a dateset annotated on CVAT
when i run the command:
python3 train_ssd.py --dataset-type=voc --data=data/training_test --model-dir=models/model_test
i get the following error:
File “train_ssd.py”, line 343, in
device=DEVICE, debug_steps=args.debug_steps, epoch=epoch)
File “train_ssd.py”, line 113, in train
for i, data in enumerate(loader):
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/dataloader.py”, line 521, in next
data = self._next_data()
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/dataloader.py”, line 1203, in _next_data
return self._process_data(data)
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/dataloader.py”, line 1229, in _process_data
data.reraise()
File “/home/user/.local/lib/python3.6/site-packages/torch/_utils.py”, line 434, in reraise
raise exception
RuntimeError: Caught RuntimeError in DataLoader worker process 0.
Original Traceback (most recent call last):
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/_utils/worker.py”, line 287, in _worker_loop
data = fetcher.fetch(index)
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/_utils/fetch.py”, line 49, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File “/home/user/.local/lib/python3.6/site-packages/torch/utils/data/dataset.py”, line 308, in getitem
return self.datasets[dataset_idx][sample_idx]
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/datasets/voc_dataset.py”, line 81, in getitem
image, boxes, labels = self.transform(image, boxes, labels)
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/ssd/data_preprocessing.py”, line 34, in call
return self.augment(img, boxes, labels)
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/transforms/transforms.py”, line 55, in call
img, boxes, labels = t(img, boxes, labels)
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/transforms/transforms.py”, line 214, in call
return torch.from_numpy(cvimage.astype(np.float32)).permute(2, 0, 1), boxes, labels
RuntimeError: Numpy is not available
searching a bit on the net i found a way recommended by @dusty_nv to debug
this is what i get:
getitem_ image_id=IMG_20220110_212704
boxes=[[ 1163.79003906 504.25 1299.86999512 625.76000977]]
labels=[1]
getitem image_id=IMG_20220110_213146
boxes=[[ 1299.88000488 1777.64001465 1654.67004395 1928.31005859]]
labels=[1]
getitem image_id=IMG_20220110_211451
boxes=[[ 547.98999023 2064.38989258 2317.12988281 2496.95996094]]
labels=[1]
data.reraise()
raise exception
I tried to delete the photo and the annotation of the last image as suggested (IMG_20220110_211451).
However I get an error again:
File “train_ssd.py”, line 214, in
target_transform=target_transform)
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/datasets/voc_dataset.py”, line 36, in init
self.ids = self._read_image_ids(image_sets_file)
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/datasets/voc_dataset.py”, line 111, in _read_image_ids
if self._get_num_annotations(image_id) > 0:
File “/home/user/Downloads/jetson-inference/python/training/detection/ssd/vision/datasets/voc_dataset.py”, line 123, in _get_num_annotations
objects = ET.parse(annotation_file).findall(“object”)
File “/usr/lib/python3.6/xml/etree/ElementTree.py”, line 1196, in parse
tree.parse(source, parser)
File “/usr/lib/python3.6/xml/etree/ElementTree.py”, line 586, in parse
source = open(source, “rb”)
FileNotFoundError: [Errno 2] No such file or directory: ‘data/training_test/Annotations/IMG_20220110_211451.xml’
i have tried debugging multiple times and it gives me a different image each time so i’m not even sure if this is the way to go.
if anyone could help me i would be grateful.
