Trained Trifinger model doesn't lift the cube off the ground
After running the train script for the Trifinger task, the learned model does not learn how to pick up the cube from the ground, rather it flips the cube over until it is close to the goal position with one finger only, then balances the cube so that there is some overlap but it does not learn as reported in the paper
