I’m currently following the tutorial Jupyter Notebook to train and use EmotionNet Model with CK+ Dataset but when i use : !tao emotionnet train -e $SPECS_DIR/emotionnet_tlt_pretrain.yaml \ -r $USER_EXPERIMENT_DIR/experiment_result/exp1 \ -k $KEY
I get this error :
2022-11-30 16:57:04,218 [INFO] root: Registry: ['nvcr.io']
2022-11-30 16:57:04,264 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
2022-11-30 16:57:04,276 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/ia/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2022-11-30 15:57:05.068300: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
Using TensorFlow backend.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-11-30 15:57:06,920 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-11-30 15:57:08,797 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py:88: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2022-11-30 15:57:08,797 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py:88: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py:88: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2022-11-30 15:57:08,797 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py:88: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
/usr/local/lib/python3.6/dist-packages/driveix/emotionnet/scripts/train.py:118: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
/workspace/tao-experiments/emotionnet/experiment_result/exp1
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/dataloader/emotionnet_dataloader.py:269: The name tf.FixedLenFeature is deprecated. Please use tf.io.FixedLenFeature instead.
WARNING 2022-11-30 15:57:09,258| tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/dataloader/emotionnet_dataloader.py:269: The name tf.FixedLenFeature is deprecated. Please use tf.io.FixedLenFeature instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING 2022-11-30 15:57:09,264| tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING 2022-11-30 15:57:09,306| tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.processors.parse_example_proto.ParseExampleProto object at 0x7ff81106a470>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.processors.parse_example_proto.ParseExampleProto object at 0x7ff81106a470>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING 2022-11-30 15:57:09,338| tensorflow: Entity <bound method Processor.__call__ of <modulus.processors.parse_example_proto.ParseExampleProto object at 0x7ff81106a470>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.processors.parse_example_proto.ParseExampleProto object at 0x7ff81106a470>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
Phase: training, num_samples: 884
INFO 2022-11-30 15:57:09,625| /usr/local/lib/python3.6/dist-packages/driveix/emotionnet/trainers/emotionnet_trainer.pyc: steps_per_epoch: 13
INFO 2022-11-30 15:57:09,625| /usr/local/lib/python3.6/dist-packages/driveix/emotionnet/trainers/emotionnet_trainer.pyc: last_step: 650
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING 2022-11-30 15:57:09,628| tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4185: The name tf.truncated_normal is deprecated. Please use tf.random.truncated_normal instead.
WARNING 2022-11-30 15:57:09,633| tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4185: The name tf.truncated_normal is deprecated. Please use tf.random.truncated_normal instead.
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/utilities/tlt_utils.py", line 150, in decode_to_keras
File "/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py", line 417, in load_model
f = h5dict(filepath, 'r')
File "/usr/local/lib/python3.6/dist-packages/keras/utils/io_utils.py", line 186, in __init__
self.data = h5py.File(path, mode=mode)
File "/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py", line 312, in __init__
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File "/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py", line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
File "h5py/h5f.pyx", line 78, in h5py.h5f.open
OSError: Unable to open file (file signature not found)
During handling of the above exception, another exception occurred:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py", line 155, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/scripts/train.py", line 144, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/trainers/emotionnet_trainer.py", line 174, in build
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/models/emotionnet_model.py", line 149, in build
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/utilities/tlt_utils.py", line 190, in model_io
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/utilities/tlt_utils.py", line 153, in decode_to_keras
OSError: Invalid decryption. Unable to open file (file signature not found). The key used to load the model is incorrect.
File "/usr/local/bin/emotionnet", line 8, in <module>
sys.exit(main())
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/emotionnet/entrypoint/emotionnet.py", line 13, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/entrypoint/entrypoint.py", line 300, in launch_job
AssertionError: Process run failed.
2022-11-30 16:57:10,514 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I looked through the forum and haven’t find how to fix it after i tryed some solution i found here.
I’m using a classical computer with a GTX 1050ti with the EmotionNet Network. tlt isn’t find in my terminal.
Thanks !
