Training image classification difficulties
hey everyone,
I’m having some difficulties running some of the code from the training image classification portion of the hello ai world tutorials. From within the container I input:
“mkdir data/cat_dog/test_cat_output data/cat_dog/test_dog_output”
I then tried to follow along by inputting:
“imagenet --model=models/cat_dog/resnet18.onnx --labels=data/cat_dog/labels.txt – input_blob=input_0 --output_blob=output_0 data/cat_dog/test/cat data/cat_dog/test_cat_output”
but then I get this error:
“URI – invalid resource or file path: –
[video] videoOptions – failed to parse input resource URI (–)
[video] videoSource – failed to parse command line options
imagenet: failed to create input stream”
Is my code incorrect? Or is there another problem going on? Any info would be awesome. Thanks!
Hi @nbarrow85, it looks like you are missing the second - before input_blob (and have a dangling space there). It should be --input-blob=input_0
Try it like this:
 imagenet --model=models/cat_dog/resnet18.onnx --labels=data/cat_dog/labels.txt --input_blob=input_0 --output_blob=output_0 data/cat_dog/test/cat data/cat_dog/test_cat_output
hey Dusty,
When I input that updated command I get this error:
“listDir(‘/usr/local/bin/data/cat_dog/test/cat’) - found no matches
[image] imageLoader – failed to find ‘data/cat_dog/test/cat’
What is the current working directory of your terminal when you run this command? Is it jetson-inference/python/training/classification?
Does your data/cat_dog/test/cat directory have image files in it?
