Anyone can help me with a training issue?
I’m trying to get my own custom object detection on Jetson AGX Orin. I start from training the model with about 2k of images, performing about 300 epochs. The objects I want to detect are about 50. At the end of the process the most part of them are well recognized (very high %), but 1-2 are never detected, even if the number of images are the same for all objects.
What can be the problem?
We have several tutorials about training an object detector.
For example:
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="pytorch-collect.md">Back</a> | <a href="pytorch-collect-detection.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning - Object Detection</sup></s></p>
# Re-training SSD-Mobilenet
Next, we'll train our own SSD-Mobilenet object detection model using PyTorch and the [Open Images](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection&c=%2Fm%2F06l9r) dataset. SSD-Mobilenet is a popular network architecture for realtime object detection on mobile and embedded devices that combines the [SSD-300](https://arxiv.org/abs/1512.02325) Single-Shot MultiBox Detector with a [Mobilenet](https://arxiv.org/abs/1704.04861) backbone.
<a href="https://arxiv.org/abs/1512.02325"><img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/pytorch-ssd-mobilenet.jpg"></a>
In the example below, we'll train a custom detection model that locates 8 different varieties of fruit, although you are welcome to pick from any of the [600 classes](https://github.com/dusty-nv/pytorch-ssd/blob/master/open_images_classes.txt) in the Open Images dataset to train your model on. You can visually browse the dataset [here](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection).
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/pytorch-fruit.jpg">
To get started, first make sure that you have [JetPack 4.4](https://developer.nvidia.com/embedded/jetpack) (or newer) and [PyTorch installed](pytorch-transfer-learning.md#installing-pytorch) for **Python 3** on your Jetson. JetPack 4.4 includes TensorRT 7.1, which is the minimum TensorRT version that supports loading SSD-Mobilenet via ONNX. Newer versions of TensorRT are fine too.
## Setup
The PyTorch code for training SSD-Mobilenet is found in the repo under [`jetson-inference/python/training/detection/ssd`](https://github.com/dusty-nv/pytorch-ssd). If you aren't [Running the Docker Container](aux-docker.md), there are a couple steps required before using it:
This file has been truncated. show original
Please check if you can get the expected custom model by following our tutorial.
Dear @AastaLLL thank you for the answer.
Of course I know this tutorial and I followed it step by step from the beginning.
However I got the issue I talked before.
Please, Have you other suggestions about it?
Thank you very much
Does every category have a similar amount of training data?
