Hello, I am trying to use the jupyter notebook that is associated with the Bevfusion model with the nuscenes dataset. I have changed the training spec file, which I have attached. But I get the following error when I try to run it.
Here is the log
Error executing job with overrides: [‘train.pretrained_checkpoint=/workspace/tao-experiments/bevfusion/bevfusion_v1.0/tao3d_bevfusion_epoch4.pth’, ‘results_dir=/results’]Traceback (most recent call last):
File “/usr/local/lib/python3.10/dist-packages/nvidia_tao_pytorch/core/decorators/workflow.py”, line 69, in _func
raise e
File “/usr/local/lib/python3.10/dist-packages/nvidia_tao_pytorch/core/decorators/workflow.py”, line 48, in _func
runner(cfg, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/nvidia_tao_pytorch/cv/bevfusion/scripts/train.py”, line 62, in main
run_experiment(experiment_config=cfg)
File “/usr/local/lib/python3.10/dist-packages/nvidia_tao_pytorch/cv/bevfusion/scripts/train.py”, line 44, in run_experiment
runner.train()
File “/usr/local/lib/python3.10/dist-packages/mmengine/runner/runner.py”, line 1728, in train
self._train_loop = self.build_train_loop(
File “/usr/local/lib/python3.10/dist-packages/mmengine/runner/runner.py”, line 1527, in build_train_loop
loop = EpochBasedTrainLoop(
File “/usr/local/lib/python3.10/dist-packages/mmengine/runner/loops.py”, line 44, in init
super().init(runner, dataloader)
File “/usr/local/lib/python3.10/dist-packages/mmengine/runner/base_loop.py”, line 26, in init
self.dataloader = runner.build_dataloader(
File “/usr/local/lib/python3.10/dist-packages/mmengine/runner/runner.py”, line 1370, in build_dataloader
dataset = DATASETS.build(dataset_cfg)
File “/usr/local/lib/python3.10/dist-packages/mmengine/registry/registry.py”, line 570, in build
return self.build_func(cfg, *args, **kwargs, registry=self)
File “/usr/local/lib/python3.10/dist-packages/mmengine/registry/build_functions.py”, line 121, in build_from_cfg
obj = obj_cls(**args) # type: ignore
File “/usr/local/lib/python3.10/dist-packages/mmengine/dataset/dataset_wrapper.py”, line 223, in init
self.dataset = DATASETS.build(dataset)
File “/usr/local/lib/python3.10/dist-packages/mmdet3d/datasets/nuscenes_dataset.py”, line 102, in init
super().init(
File “/usr/local/lib/python3.10/dist-packages/mmdet3d/datasets/det3d_dataset.py”, line 126, in init
super().init(
TypeError: BaseDataset.init() got an unexpected keyword argument ‘origin’
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
E1009 14:47:16.990000 129253466547328 torch/distributed/elastic/multiprocessing/api.py:881] failed (exitcode: 1) local_rank: 0 (pid: 420) of binary: /usr/bin/python
File “/usr/local/bin/torchrun”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.10/dist-packages/torch/distributed/elastic/multiprocessing/errors/init.py”, line 347, in wrapper
return f(*args, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/torch/distributed/run.py”, line 879, in main
run(args)
File “/usr/local/lib/python3.10/dist-packages/torch/distributed/run.py”, line 870, in run
elastic_launch(
File “/usr/local/lib/python3.10/dist-packages/torch/distributed/launcher/api.py”, line 132, in call
return launch_agent(self._config, self._entrypoint, list(args))
File “/usr/local/lib/python3.10/dist-packages/torch/distributed/launcher/api.py”, line 263, in launch_agent
raise ChildFailedError(
torch.distributed.elastic.multiprocessing.errors.ChildFailedError:
The error is as above. You can add debug code to check further.
You can open a terminal and run below. $docker run --runtime=nvidia -it --rm nvcr.io/nvidia/tao/tao-toolkit:5.5.0-pyt /bin/bash
Then inside the docker, you can run training. #bevfusion train xxx
All the codes can be found under
More, please run with default notebook firstly to get familiar with the steps.
Then you can leverage the default kitti dataset training and check if there is gap in format/spec/etc between Kitti and Nuscenes.
