I am using NVDec -> NVEnc that is setup fairly similar to the nv_transcode example included in the SDK.
I have a requirement where several source files are interlaced and need to be transcoded to progressive. I do not see an option anywhere in the encoder API to force progressive output.
I saw NV_ENC_H264_PROFILE_PROGRESSIVE_HIGH_GUID which I thought might work but it seems to just freeze the whole process if I set that as the active H264 profile.
Does anyone know how to approach this issue?
