Transfer Timing using events vs windows
I’m transferring up 192kb data blocks (with pinned memory), and although cuda events see it go up at 5gb/sec, by the time we get back to windows we only see half that speed. Is this just unavoidable driver overhead, or are there ways to mitigate this? I’ve encapsulated the process in the test program below.
void transferUp(size_t size)
StopWatchWin timer;
timer.start();
float tUpCopyStart,tUpCopyStop;
cudaEvent_t sendUpStopEvent,sendUpStartEvent;
checkCudaErrors(cudaEventCreate( &sendUpStartEvent ));
checkCudaErrors(cudaEventCreate( &sendUpStopEvent ));
unsigned *cpu_sending = (unsigned *)malloc(size);
checkCudaErrors(cudaHostAlloc(&cpu_sending, size*sizeof(unsigned), cudaHostAllocPortable));
unsigned *gpu_receiving;
checkCudaErrors(cudaMalloc(&gpu_receiving, size*sizeof(unsigned)));
tUpCopyStart = timer.getTime();
checkCudaErrors(cudaEventRecord(sendUpStartEvent));
checkCudaErrors(cudaMemcpyAsync(gpu_receiving, cpu_sending, size*sizeof(unsigned), cudaMemcpyHostToDevice));
checkCudaErrors(cudaEventRecord(sendUpStopEvent));
checkCudaErrors(cudaEventSynchronize(sendUpStopEvent));
tUpCopyStop = timer.getTime();
double sendTimeWindows = tUpCopyStop - tUpCopyStart;
float sendTimeCuda;
checkCudaErrors(cudaEventElapsedTime( &sendTimeCuda,sendUpStartEvent,sendUpStopEvent));
float GbSec_cuda =  (size*sizeof(unsigned)/1000)/(sendTimeCuda*1000);
float GbSec_win =  (size*sizeof(unsigned)/1000)/(sendTimeWindows*1000);
printf("size=%06d bytes eventTime=%.03fms windowsTime=%0.3fms cudaSpeed=%.01f gb/s winSpeed=%.01f gb/s\n",
		size*sizeof(unsigned),sendTimeCuda,sendTimeWindows,GbSec_cuda,GbSec_win);
checkCudaErrors(cudaEventDestroy( sendUpStartEvent ));
checkCudaErrors(cudaEventDestroy( sendUpStopEvent ));
checkCudaErrors(cudaFreeHost(cpu_sending));
checkCudaErrors(cudaFree(gpu_receiving));
