Is there some standard way how to transfer tracked objects user metadata across batches?
In my use case for each tracked object that enters RoI for the first time I generate UUID, save it as objects user metadata that is then published to the broker. (this work as intended, message with UUID is published)
Later when this tracked object leaves RoI I would need to access previously generated UUID from objects user metadata so it can be again published to the broker.
Yes I can, both C++ and python reference works with me. In my current app UUID is already generated in a probe function. Also I am using base_meta.copy_func to copy it between buffers so I assume there could be such functionality for transfer between batches as well but I was not able to find it. Is there such function or I need to implement it?
