I am working with testing and comparison between the performance of various messaging broker protocols i.e. Apache Kafka, RabbitMQ etc with the Deepstream SDK.
Latency of sending a frame and receiving it on the consumer side is my preferred metric of performance measurement.
Any leads and opinions for the same will be of great help.
I tried running deepstream-test4 sample application.
I am running a rabbitmq-server on a separate ubuntu machine.
My cfg_amqp.txt looks like this.
[message-broker]
password = guest #optional
hostname = 172.17.26.76
username = guest
port = 5672
exchange = amq.topic
topic = topicname
And the Error that I’m getting this error : Could not configure library, cannot connect to broker library.
I’m just not sure what is the right way to pass the hostname ( since my broker is running on IP : 172.17.26.76 ). Can you please let me know the correct way of passing the hostname in cfg_amqp.txt.
Hi
Can you try with this sample test code:
/opt/nvidia/deepstream/deepstream-4.0/sources/libs/amqp_protocol_adaptor/
it’s demonstrating connect to amqp broker and sending hello message.
or still with test4 sample change hostname = localhost and try again?
I was able to solve the problem.
In order to access the rabbitmq broker remotely, we have to create a new user on our rabbitmq-server with administrator tag.
After creating the new user and setting permissions to the new user over rabbitmq, I was able to execute deepstream-test4 and deepstream-test5 sample applications.
Now, I want to send a serialized Mat object using the code test_amqp_proto_async.cpp OR test_amqp_proto_sync.cpp in the directory amqp_protocol_adaptor.
Although I’m able to send Hello to the rabbitmq-server and I’m able to listen to the incoming messages, I can’t consume them.
Please help me with the consumer implementation.
We do not have latency data. you will have to change the message broker in test 4 or test 5 to do that and only metadata can be sent. Test 4 will not send image frames, if that is needed you will need to customize the code
