I’ve tried your codelet of isaac_ros_bridge_codelets.
I think I have followed your procedure. However I encountered some errors.
bazel run apps/isaac_ros_bridge_codelets/odom_publisher:carter_sim_ros_odom_pub – --config=“apps/assets/maps/carter_warehouse_p.config.json” --graph=“apps/assets/maps/carter_warehouse_p.graph.json”
WARNING: /home/dellstation/isaac-sdk-2019.2/isaac-sdk-2019.2-30e21124/packages/viewers/BUILD:14:12: in srcs attribute of cc_binary rule //packages/viewers:libviewers_module.so: please do not import ‘//packages_x86_64/viewers:libviewers_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
WARNING: /home/dellstation/isaac-sdk-2019.2/isaac-sdk-2019.2-30e21124/packages/perception/BUILD:34:12: in srcs attribute of cc_binary rule //packages/perception:libperception_module.so: please do not import ‘//packages_x86_64/perception:libperception_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/isaac_ros_bridge_codelets/odom_publisher:carter_sim_ros_odom_pub (0 packages loaded, 0 targets configured).
INFO: Found 1 target…
Target //apps/isaac_ros_bridge_codelets/odom_publisher:carter_sim_ros_odom_pub up-to-date:
bazel-genfiles/apps/isaac_ros_bridge_codelets/odom_publisher/run_carter_sim_ros_odom_pub
bazel-bin/apps/isaac_ros_bridge_codelets/odom_publisher/carter_sim_ros_odom_pub
INFO: Elapsed time: 0.272s, Critical Path: 0.00s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
INFO: Running command line: bazel-bin/apps/isaac_ros_bridge_codelets/odom_publisher/carter_sim_ros_odom_pub ‘–config=apps/assets/maps/carter_warehouse_p.config.json’ '–graph=apps/assets/maps/carter_warehouse_p.grINFO: Build completed successfully, 1 total action
2020-04-27 14:33:56.440 INFO engine/alice/tools/websight.cpp@166: Loading websight…
2020-04-27 14:33:56.441 WARNING engine/alice/backend/application_json_loader.cpp@98: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system’s abilities if possible.
2020-04-27 14:33:56.446 WARNING engine/alice/backend/backend.cpp@168: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-04-27 14:33:56.446 WARNING engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 64 remaining cores. This may be non optimal for the system and application.
2020-04-27 14:33:56.446 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-04-27 14:33:56.446 INFO engine/gems/scheduler/scheduler.cpp@299: BlockerGroup: Cores = [48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63], Workers = No
2020-04-27 14:33:56.446 INFO engine/gems/scheduler/scheduler.cpp@299: WorkerGroup: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47], Workers = Yes
2020-04-27 14:33:56.456 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/flatsim/libflatsim_module.so’: Now has 53 components total
2020-04-27 14:33:56.464 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/map/libmap_module.so’: Now has 54 components total
2020-04-27 14:33:56.473 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/navigation/libnavigation_module.so’: Now has 85 components total
2020-04-27 14:33:56.485 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/perception/libperception_module.so’: Now has 95 components total
2020-04-27 14:33:56.495 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/planner/libplanner_module.so’: Now has 103 components total
2020-04-27 14:33:56.505 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/sensors/libjoystick_module.so’: Now has 104 components total
2020-04-27 14:33:56.515 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/sight/libsight_module.so’: Now has 105 components total
2020-04-27 14:33:56.527 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/viewers/libviewers_module.so’: Now has 121 components total
2020-04-27 14:33:56.527 ERROR engine/alice/backend/modules.cpp@307: //isaac_ros_bridge_codelets/odom_publisher:ros_odom_pub_components: /home/dellstation/.cache/bazel/_bazel_dellstation/2cdfd8d69a6ddb1b4ca35a3cc5770ea6/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/isaac_ros_bridge_codelets/odom_publisher/carter_sim_ros_odom_pub.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/isaac_ros_bridge_codelets/odom_publisher/libros_odom_pub_components_module.so: cannot open shared object file: No such file or directory
2020-04-27 14:33:56.527 PANIC engine/alice/backend/modules.cpp@309: Could not load all required modules for application
| Isaac application terminated unexpectedly |
#01 engine/alice/tools/main(+0x8044a) [0x561b8c2a144a]
#02 engine/alice/tools/main(+0xe8710) [0x561b8c309710]
#03 engine/alice/tools/main(+0xe8a80) [0x561b8c309a80]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f57d7859890]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f57d6ef3e97]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f57d6ef5801]
#07 engine/alice/tools/main(+0x9d1d7) [0x561b8c2be1d7]
#08 engine/alice/tools/main(+0x34bdc) [0x561b8c255bdc]
#09 engine/alice/tools/main(+0x350f3) [0x561b8c2560f3]
#10 engine/alice/tools/main(+0x352e4) [0x561b8c2562e4]
#11 engine/alice/tools/main(+0x15c23) [0x561b8c236c23]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f57d6ed6b97]
#13 engine/alice/tools/main(+0x1af7a) [0x561b8c23bf7a]
Minidump written to: /tmp/36c9cee7-76f1-45e5-04a27bbb-cdf87d23.dmp
Aborted (core dumped)
