Transparent inter-GPU memory migration
I’m planning to implement a “transparent” inter-GPU memory migration using the virtual memory management functions provided by the CUDA driver APIs. As this tech blog shows, the cuMemMap API allows programmers to bind a reserved virtual memory range to a allocated physical memory handle. So during a process’s execution, can we allocate a new physical memory handle on GPU 1, then copy the data from GPU 0 to GPU 1, and finally re-map the assigned virtual address (e.g., returned by cuMemAddressReserve) to the new handle on the other GPU?
cuCtxSetCurrent(ctx_gpu0);
cuCtxEnablePeerAccess(ctx_gpu1, 0);
cuCtxEnablePeerAccess(ctx_gpu0, 0);
cuMemAddressReserve(&device_ptr, size, 0ULL, 0ULL, 0ULL);
cuMemCreate(&handle, size, &prop, 0);
cuMemMap(device_ptr, size, 0ULL, handle, 0ULL);
cuMemSetAccess(device_ptr, size, &access_desc, 1ULL);
vec_add<<<>>>(device_ptr);
cuCtxSetCurrent(ctx_gpu1);
// Create new handle and bind to new_ptr...
cuMemcpyPeer(new_ptr, ctx_gpu1, device_ptr, ctx_gpu0, size);
cuMemMap(device_ptr, size, 0ULL, new_handle, 0ULL)
vec_add<<<>>>(device_ptr);  // Error: unspecified launch failure
The first kernel launch succeeds but the second kernel after migration fails due to unspecified launch failure CUDA runtime error.
do you do any error checking?
Yes. All the driver APIs report NO error.
#include "utils/cudadrv.hpp"
#include "utils/cudart.hpp"
#include <cstdio>
#include <numeric>
#include <vector>
template <typename T>
__global__ void vec_add_one(T *arr, uint32_t n) {
  uint32_t tid = threadIdx.x + blockIdx.x * blockDim.x;
  for (uint32_t i = tid; i < n; i += gridDim.x * blockDim.x) {
    arr[i] += i;
struct ScopedContext {
  explicit ScopedContext(CUcontext ctx) {
    CUDADRV_CHECK(cuCtxSetCurrent(ctx));
  ~ScopedContext() {
    CUDADRV_CHECK(cuCtxSetCurrent(nullptr));
// A possible cuMalloc implementation using CUDA driver API
struct CudaMmapProxy {
  std::vector<CUcontext> cu_contexts_;
  std::vector<uint32_t> devices_;
  explicit CudaMmapProxy() {
    CUDADRV_CHECK(cuInit(0));
    int num_devices = 0;
    CUDADRV_CHECK(cuDeviceGetCount(&num_devices));
    devices_.reserve(num_devices);
    std::iota(devices_.begin(), devices_.end(), 0);
    for (uint32_t i = 0; i < num_devices; ++i) {
      CUcontext ctx;
      CUDADRV_CHECK(cuCtxCreate(&ctx, 0, i));
      cu_contexts_.push_back(ctx);
    int access;
      CUDADRV_CHECK(cuCtxSetCurrent(cu_contexts_[i]));
      for (uint32_t j = 0; j < num_devices; ++j) {
        if (i == j) {
          continue;
        CUDADRV_CHECK(cuDeviceCanAccessPeer(&access, i, j));
        if (access) {
          std::printf("Peer access enabled between %d and %d\n", i, j);
          CUDADRV_CHECK(cuCtxEnablePeerAccess(cu_contexts_[j], 0));
      // CUDADRV_CHECK(cuCtxSetCurrent(nullptr));
  ~CudaMmapProxy() {
    for (auto ctx : cu_contexts_) {
      CUDADRV_CHECK(cuCtxDestroy(ctx));
  CUcontext context(uint32_t i) {
    return cu_contexts_[i];
struct CudaMmapAllocation {
  size_t size_{0}, align_size_{0};
  CUmemGenericAllocationHandle handle_;
  CUmemAccessDesc access_desc_;
  CUcontext ctx_{nullptr};
  CUdeviceptr device_ptr_;
  CudaMmapAllocation(CUcontext ctx, size_t size) {
    int device_id;
    ScopedContext _{ctx};
    CUDADRV_CHECK(cuCtxGetDevice(&device_id));
    ctx_ = ctx;
    CUmemAllocationProp prop{};
    prop.type = CU_MEM_ALLOCATION_TYPE_PINNED;
    prop.location.type = CU_MEM_LOCATION_TYPE_DEVICE;
    prop.location.id = device_id;
    access_desc_.location = prop.location;
    access_desc_.flags = CU_MEM_ACCESS_FLAGS_PROT_READWRITE;
    CUDADRV_CHECK(cuMemGetAllocationGranularity(&align_size_, &prop, CU_MEM_ALLOC_GRANULARITY_MINIMUM));
    size_ = ((size + align_size_ - 1) / align_size_) * align_size_;
    CUDADRV_CHECK(cuMemAddressReserve(&device_ptr_, size_, 0ULL, 0ULL, 0ULL));
    CUDADRV_CHECK(cuMemCreate(&handle_, size_, &prop, 0));
    CUDADRV_CHECK(cuMemMap(device_ptr_, size_, 0ULL, handle_, 0ULL));
    CUDADRV_CHECK(cuMemSetAccess(device_ptr_, size_, &access_desc_, 1ULL));
  ~CudaMmapAllocation() {
    if (size_ > 0) {
      ScopedContext _{ctx_};
      // CUDADRV_CHECK(cuMemAddressFree(device_ptr_, size_));
      CUDADRV_CHECK(cuMemRelease(handle_));
  template <typename T = void>
  T *ptr() {
    return reinterpret_cast<T *>(device_ptr_);
  void migrate(CUcontext ctx) {
    // Migrate the managed memory from current device to `to_device`
    CUmemAllocationProp old_prop{};
    CUDADRV_CHECK(cuMemGetAllocationPropertiesFromHandle(&old_prop, handle_));
    // CUDADRV_CHECK(cuCtxSetCurrent(ctx));
    CUmemAllocationProp new_prop{};
    new_prop.type = CU_MEM_ALLOCATION_TYPE_PINNED;
    new_prop.location.type = CU_MEM_LOCATION_TYPE_DEVICE;
    CUmemAccessDesc new_access_desc;
    new_access_desc.flags = CU_MEM_ACCESS_FLAGS_PROT_READWRITE;
    CUdeviceptr new_ptr;
    CUmemGenericAllocationHandle new_handle;
    int old_device, new_device;
    CUDADRV_CHECK(cuCtxGetDevice(&old_device));
      CUDADRV_CHECK(cuCtxGetDevice(&new_device));
      new_prop.location.id = new_device;
      new_access_desc.location = new_prop.location;
      // Allocate physical memory on the target device
      CUDADRV_CHECK(cuMemCreate(&new_handle, size_, &new_prop, 0));
      CUDADRV_CHECK(cuMemAddressReserve(&new_ptr, size_, 0ULL, 0ULL, 0ULL));
      // Map to a temporary VA range
      CUDADRV_CHECK(cuMemMap(new_ptr, size_, 0ULL, new_handle, 0ULL));
      CUDADRV_CHECK(cuMemSetAccess(new_ptr, size_, &new_access_desc, 1ULL));
      // Copy from source device to target device
      CUDADRV_CHECK(cuMemcpyPeer(new_ptr, ctx, device_ptr_, ctx_, size_));
    // Remap
    CUDADRV_CHECK(cuMemUnmap(device_ptr_, size_));
    CUDADRV_CHECK(cuMemUnmap(new_ptr, new_handle));
    CUDADRV_CHECK(cuMemAddressFree(new_ptr, size_));
    // CUDADRV_CHECK(cuMemAddressReserve(&device_ptr_, size_, 0ULL, 0ULL, 0ULL));
    CUDADRV_CHECK(cuMemMap(device_ptr_, size_, 0ULL, new_handle, 0ULL));
    CUDADRV_CHECK(cuMemSetAccess(device_ptr_, size_, &new_access_desc, 1ULL));
    handle_ = new_handle;
    ctx_ = ctx;
    // device_ptr_ = new_ptr;
    access_desc_ = new_access_desc;
uint32_t pointer_device(const void *ptr) {
  cudaPointerAttributes ptr_attr{};
  CUDART_CHECK(cudaPointerGetAttributes(&ptr_attr, ptr));
  return ptr_attr.device;
int main() {
  auto proxy = CudaMmapProxy();
  size_t size = 2048;
  auto alloc = CudaMmapAllocation(proxy.context(0), size);
  auto *device_ptr = alloc.ptr<int>();
  CUDADRV_CHECK(cuCtxSetCurrent(proxy.context(0)));
  CUDART_CHECK(cudaMemset(device_ptr, 0, size));
  vec_add_one<<<1, 256>>>(device_ptr, size / sizeof(int));
  std::vector<int> host_data(size / sizeof(int), 0);
  CUDART_CHECK(cudaMemcpy(host_data.data(), device_ptr, size, cudaMemcpyDeviceToHost));
  CUDART_CHECK(cudaDeviceSynchronize());
  // for (uint32_t i = 0; i < host_data.size(); ++i) {
  //   std::printf("data[%d] = %d\n", i, host_data[i]);
  std::printf("Before migrate: %d\n", pointer_device(device_ptr));
  uint32_t new_device = 1;
  alloc.migrate(proxy.context(new_device));
  std::printf("After migrate: %d\n", pointer_device(device_ptr));
  int cu_device;
  CUDADRV_CHECK(cuCtxGetDevice(&cu_device));
  std::printf("Current context device: %d\n", cu_device);
  // device_ptr = alloc.ptr<int>();
  return 0;
Here is the whole code snippet.
compute-sanitizer ./bin/mmap
========= COMPUTE-SANITIZER
Peer access enabled between 0 and 1
Peer access enabled between 0 and 2
Peer access enabled between 0 and 3
Peer access enabled between 0 and 4
Peer access enabled between 1 and 0
Peer access enabled between 1 and 2
Peer access enabled between 1 and 3
Peer access enabled between 1 and 4
Peer access enabled between 2 and 0
Peer access enabled between 2 and 1
Peer access enabled between 2 and 3
Peer access enabled between 2 and 4
Peer access enabled between 3 and 0
Peer access enabled between 3 and 1
Peer access enabled between 3 and 2
Peer access enabled between 3 and 4
Peer access enabled between 4 and 0
Peer access enabled between 4 and 1
Peer access enabled between 4 and 2
Peer access enabled between 4 and 3
Before migrate: 0
After migrate: 1
Current context device: 1
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaLaunchKernel.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame: [0x45f2e6]
=========                in /lib/x86_64-linux-gnu/libcuda.so.1
=========     Host Frame:cudaLaunchKernel [0x6d5bb]
=========                in /usr/local/cuda/lib64/libcudart.so.12
=========     Host Frame:/tmp/tmpxft_00035395_00000000-7_mmap.cudafe1.stub.c:13:__device_stub__Z11vec_add_oneIiEvPT_j(int*, unsigned int) [0x282e]
=========                in /home/bin/mmap
=========     Host Frame:/home/src/mmap.cu:199:main [0x257d]
=========     Host Frame:__libc_start_main [0x23d0a]
=========                in /lib/x86_64-linux-gnu/libc.so.6
=========     Host Frame:_start [0x26da]
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaMemcpy.
=========     Host Frame:cudaMemcpy [0x68708]
=========     Host Frame:/home/src/mmap.cu:199:main [0x2594]
CUDART assertion failed: unspecified launch failure /home/src/mmap.cu 199
========= Target application returned an error
========= ERROR SUMMARY: 2 errors
Here is the result of compute-sanitizer. And I’m using A100 with CUDA 12.2.
