Transparent plastic wrap is invisible
Hello.
When I load asset Pallet w/ cardboard boxes in isaac sim, (e.g. NVIDIA/Assets/DigitalTwin/Assets/Warehouse/Shipping/Cardboard_Boxes_on_Pallet/Pallet_Asm_A/Pallet_Asm_A04_120x122x75cm_PR_V_NVD_01.usd), a plastic transparent wrap prim exists but cannot see it from rendered object in viewport.
I can see the transparant cover from below ‘content’ icons, but It disappears when I load it to viewport.
How can I load the transparent wrap?
It is there and working normally, but it does not show up well in the REALTIME mode. If you switch to Path tracing mode you will see it fine. It is just because it is a very thin single sheet of transparency and if you don’t have the right rendering settings it will not show up. You can manually adjust the material as well if you needed to.
