I’m trying to implement a runs-based CLL algorithm using Numba where I need to traverse the elements of a 3D matrix on a row per thread basis i.e. each thread is assigned a row that iterates over all elements of that row.
For example, if, for simplicity, I were to use a 2D matrix with 50 rows and 100 columns, I would need to create 50 threads that would go through the 100 elements of their respective row.
Can someone tell me how to do this iteration?
Turns out it’s actually quite simple. You only need to launch as many threads as rows and have the kernel “point” its direction.
Here’s a simple kernel that demonstrates how to do such an iteration over a 3D matrix (binary_image). The kernel itself is part of the CCL algorithm I’m implementing but that can safely be ignored :
from numba import cuda
@cuda.jit
def kernel_1(binary_image, image_width, s_matrix, labels_matrix):
# notice how we're only getting the row and depth of each thread
row, image_slice = cuda.grid(2)
sm_pos, lm_pos = 0, 0
span_found = False
if row < binary_image.shape[0] and image_slice < binary_image.shape[2]: # guard for rows and slices
# and here's the traversing over the columns
for column in range(binary_image.shape[1]):
if binary_image[row, column, image_slice] == 0:
if not span_found: # Connected Component found
span_found = True
s_matrix[row, sm_pos, image_slice] = column
sm_pos = sm_pos + 1
# converting 2D coordinate to 1D
linearized_index = row * image_width + column
labels_matrix[row, lm_pos, image_slice] = linearized_index
lm_pos = lm_pos + 1
else:
elif binary_image[row, column, image_slice] == 255 and span_found:
span_found = False
s_matrix[row, sm_pos, image_slice] = column - 1
sm_pos = sm_pos + 1
This will suffer from poor memory access patterns, which would be a general criticism of any “thread per row” approach, assuming we mean a row as in C-style row-major storage.
I’m unaware if there’s a better pattern in this scenario.
In this context, I’m implementing a CCL runs-based algorithm (hence thread per row) - as opposed to a voxel-based approach which I assume leans more towards the one thread per element pattern.
