Tried to boot Nano with 6.2 - system is not responsive no video even after removing sd card
Followed the instructions - imaged the sd card - ut it in and booted - nothing - system is no non functional - weirdly - ctrl alt del on attached usb keyboard results in fan stoping on module - any thoughts on getting this working again
Link to instructions: JetPack SDK | NVIDIA Developer
Too coincidental to be it chose that moment to fail - No video out at all - direct connect to a displayport - was working until I rebooted with th 6.2 image
Hi @paulcayley since your Orin Nano is not booting it might be better to flash the card again. I would recommend flashing with SDK Manager, we have a guide that you can follow:
You will need to put the Orin Nano in recovery mode, the guide includes how to do it for the Orin AGX, but for the Orin Nano you need to short pins 9 and 10 in J14 header, the pins are labeled as FC_REC and GND respectively.
If the board is in recovery mode your PC will detect it as the following:
lsusb #Example output: Bus 003 Device 029: ID 0955:7523 NVIDIA Corp. APX
We recommend to use the sdk manager to full flash the device.
