Hardware Platform (Jetson / GPU)
Jetson NX
• DeepStream Version
5.1
4.5-b129
• TensorRT Version
7.1.3
After correctly running
python3 deepstream_test1_rtsp_out.py -i ../../../samples/streams/sample_720p.h264
Basically, there should be a rtsp stream on rtsp://localhost:8554/ds-test , is that righht?
And I am trying that output the rtsp stream on website with cv2 and flask. The code that I use is
from flask import Flask, render_template, Response
import cv2
from gevent.pywsgi import WSGIServer
import os
app = Flask(__name__)
print(cv2.getBuildInformation())
os.environ["OPENCV_FFMPEG_CAPTURE_OPTIONS"] = "rtsp_transort;udp"
camera = cv2.VideoCapture('rtsp://myusername:mypassword@localhost:8554/ds-test', cv2.CAP_FFMPEG) # use 0 for web camera
# for cctv camera use
# for local webcam use cv2.VideoCapture(0)
def gen_frames(): # generate frame by frame from camera
while True:
# Capture frame-by-frame
success, frame = camera.read() # read the camera frame
if not success:
break
else:
ret, buffer = cv2.imencode('.jpg', frame)
frame = buffer.tobytes()
yield (b'--frame\r\n'
b'Content-Type: image/jpeg\r\n\r\n' + frame + b'\r\n') # concat frame one by one and show result
@app.route('/video_feed')
def video_feed():
#Video streaming route. Put this in the src attribute of an img tag
return Response(gen_frames(), mimetype='multipart/x-mixed-replace; boundary=frame')
@app.route('/')
def index():
"""Video streaming home page."""
return render_template('index.html')
if __name__ == '__main__':
#app.run(debug=True)
app.debug = True
http_server = WSGIServer(('0.0.0.0', 8888), app)
http_server.serve_forever()
but got the error,
[rtsp @ 0x5597e22600] method DESCRIBE failed: 503 Service Unavailable
rtsp://localhost:8554/ds-test: Server returned 5XX Server Error reply
Any comments on this? Please share with me!
