I am using persistent thread model with threads never exiting. The persistent threads periodically does a handshake with host using host pinned memory. So the execution flow is something like this:
Host threads: Device THreads:
launch kernel
start running
do foo()
keep spinning (polling) ...
till device tells it is indicate to host that foo() is done
done doing foo() (write to pinned memory)
do bar() keep doing foo()
The issue with above model is that host threads basically need to use polling (spinning). Is there a method to convert this polling to blocking? (Provided persistent threads can’t exit) I am okay with ugly hacks also.
