Tripwire not showing in and out after reboot
After I reboot the device and typed command
sudo docker compose -f compose_nx.yaml up -d –-force-recreate
go to live streams and press Show Tripwire
it should got something like this
What is your question? Does you mean the analytics counting is wrong? What is your expectation?
Tripwire doesn’t show Counter for “in and out” i pressed [Show] Button after reboot
only to make them appear is to remove old tripwire and draw new tripwire
Are you get above image from mobile app or VST web UI?
I got the above image from VST web UI
the image below is what it should have when I show Tripwire
