I succesfully installed triton inference server to my local computer. I tried to run the server but i got the error libdcgm.so.2 cannot opened. I am sure that i succesfully installed nvdia dcgm as well. Do you have an idea why i am getting the error?
/opt/tritonserver2/bin/tritonserver: error while loading shared libraries: libdcgm.so.2: cannot open shared object file: No such file or directory
Hey It is me again. Yesterday, I tried to run the server and it worked out. But I still got the same error libdcgm.so.2 today .It is so weird. So,t here is still no progress. I would appreciate your support.
Given it worked one day and not the next this sounds like an ldconfig issue which (if so) you can fix with either an export LD_LIBRARY_PATH= or putting the same path in /etc/ld.so.conf and running ldconfig which would fix it system wide for other user environments as well
