I am running a Triton server serving a SSD model plan generated by the TAO toolkit
Serving works fine! but I am trying to parse the results. here is a sample request and response
image_path = 'test_images/frame_002541.png' # read an image
## pre-proces the image
img = cv2.imread(image_path)
offsets = np.array([103.939,116.779,123.68]) # BGR color offsets
infer_dims = [3, 736, 1280]
#convert the image to float32 and subtract the offsets
img = img.astype(np.float32)
img -= offsets
# rescale the imaage to infer_dims
img = cv2.resize(img, (infer_dims[2], infer_dims[1]))
# show image shape
print('Image shape: ', img.shape)
# convert the image to CHW format
img = img.transpose([2, 0, 1])
The Trition server is configured to accept CHW (736, 1280) images.
Now we make a connection (I have ports mapped so please don;t worry about the strange port numbers)
# Setup a connection with the Triton Inference Server.
triton_client = httpclient.InferenceServerClient(url="localhost:9100", verbose=True, concurrency=1, insecure=True)
# get some model metadata
try:
model_metadata = triton_client.get_model_metadata(model_name="my-model-v2", model_version="1")
except InferenceServerException as e:
print("Failed to retrieve the metadata: {}".format(e))
# get model config
try:
model_config = triton_client.get_model_config(model_name="my-model-v2", model_version="1")
print("Model config:\n{}".format(model_config))
print("Failed to retrieve the config: {}".format(e))
get metadata and config
print("Model inputs:{} | LEN {}".format(model_metadata['inputs'], len(model_metadata['inputs'])))
print(f"Model outputs:{model_metadata['outputs']} | LEN {len(model_metadata['outputs'])} \n")
print(f"model config inputs: {model_config['input']} | LEN {len(model_config['input'])}")
print(f"model config outputs: {model_config['output']} | LEN {len(model_config['output'])} \n")
result
Model inputs:[{'name': 'Input', 'datatype': 'FP32', 'shape': [3, 736, 1280]}] | LEN 1
Model outputs:[{'name': 'NMS', 'datatype': 'FP32', 'shape': [1, 1, 10, 7]}, {'name': 'NMS_1', 'datatype': 'FP32', 'shape': [1, 1, 1, 1]}] | LEN 2
model config inputs: [{'name': 'Input', 'data_type': 'TYPE_FP32', 'format': 'FORMAT_NONE', 'dims': [3, 736, 1280], 'reshape': {'shape': [1, 3, 736, 1280]}, 'is_shape_tensor': False, 'allow_ragged_batch': False, 'optional': False}] | LEN 1
model config outputs: [{'name': 'NMS', 'data_type': 'TYPE_FP32', 'dims': [1, 1, 10, 7], 'reshape': {'shape': [1, 1, 10, 7]}, 'label_filename': '', 'is_shape_tensor': False}, {'name': 'NMS_1', 'data_type': 'TYPE_FP32', 'dims': [1, 1, 1, 1], 'reshape': {'shape': [1, 1, 1, 1]}, 'label_filename': '', 'is_shape_tensor': False}] | LEN 2
setting up input and output
# Specify the names of the input and output layer(s) of our model.
test_input = httpclient.InferInput("Input", image_data.shape, datatype="FP32")
test_input.set_data_from_numpy(image_data)
output_0 = httpclient.InferRequestedOutput("NMS",)
output_1 = httpclient.InferRequestedOutput("NMS_1")
making the inference request
try:
results = triton_client.infer(model_name="my-model-v2",
inputs=[test_input],
request_id="1",
model_version="1",
outputs=[output_0, output_1]
print("inference failed: {}".format(e))
print response
print(results.get_response())
output
{'id': '1', 'model_name': 'nozzlenet-v2', 'model_version': '1', 'outputs': [{'name': 'NMS', 'datatype': 'BYTES', 'shape': [10], 'parameters': {'binary_data_size': 144}}, {'name': 'NMS_1', 'datatype': 'BYTES', 'shape': [1], 'parameters': {'binary_data_size': 14}}]}
After this point I’m not sure how to capture this binary data to the right structure? (or is there a way I can have something like a JSON/dictionary rather than binary to begin with so I can see how the data is packaged so I can deal with the binary data later?
I tried in a crude way to see how the items in the results are stored and then re arrange it but the lists in the elements seem to not have a fixed size?
because I expected to see a 10x7 arrangement where if I pick a row (one in 10) there will be 7 sub elements. (this could be still the case but I may be missing something /lacking understanding)
my crude method is described below: I tried working back from sizes by doing the steps below
output = results.as_numpy("NMS")
# prinnt output data type
print(f"Output data type: {output.dtype.type}")
print(f"Output shape: {len(output)}")
output
Output data type: <class 'numpy.object_'>
Output shape: 10
then i looked at indivdual items to see if they are arranged in a consistent way
# get the size if output_0 in memory
output_0_size = sys.getsizeof(output_0)
print(f"Output 0 size: {output_0_size}")
# get the size if output_1 in memory
output_1_size = sys.getsizeof(output_1)
print(f"Output 1 size: {output_1_size}")
# get the sixe of of output_2
output_2_size = sys.getsizeof(output_2)
print(f"Output 2 size: {output_2_size}")
# get the size of output_3
output_3_size = sys.getsizeof(output_3)
print(f"Output 3 size: {output_3_size}")
# get the size of output_4
output_4_size = sys.getsizeof(output_4)
print(f"Output 4 size: {output_4_size}")
# get the size of output_5
output_5_size = sys.getsizeof(output_5)
print(f"Output 5 size: {output_5_size}")
# get the size of output_6
output_6_size = sys.getsizeof(output_6)
print(f"Output 6 size: {output_6_size}")
# get the size of output_7
output_7_size = sys.getsizeof(output_7)
print(f"Output 7 size: {output_7_size}")
# get the size of output_8
output_8_size = sys.getsizeof(output_8)
print(f"Output 8 size: {output_8_size}")
# get the size of output_9
output_9_size = sys.getsizeof(output_9)
print(f"Output 9 size: {output_9_size}")
# get the size of all the elements in output
output_size = sys.getsizeof(output)
print(f"Output size: {output_size}")
I got
Output 0 size: 43
Output 1 size: 43
Output 2 size: 44
Output 3 size: 43
Output 4 size: 44
Output 5 size: 43
Output 6 size: 44
Output 7 size: 44
Output 8 size: 43
Output 9 size: 43
Output size: 112
Can you help me make sense of my output (should be easy as I know that my NMS is [1, 1, 10, 7] the output list is 10 items long so i reckon there should be 7 elements on one list items (but 43 and 44 byte sizes throw me off)
can you pleae help me or point me to the right documentation?
Cheers,
Ganindu.
