I am trying to install Triton inference server from source file (according to published latest release: Releases · triton-inference-server/server · GitHub)
Below are my system information:
Nvidia Jetson Nano,
Ubuntu 18.04 LTS
Jetpack 4.6
I have download the file called tritonserver2.12.0-jetpack4.6.tgz file but, I am not be able to compile/install Triton Server.
When I try to execute following code, it says ‘bash: tritonserver: command not found’
tritonserver --model-repository=/path/to/model_repo --backend-directory=/path/to/tritonserver/backends \ –backend-config=tensorflow,version=2
How can I compile/install and run triton inference server?
What should I do with source code file (tar.gz file at the bottom)?
I have attached the image of tritonserver2.12.0-jetpack4.6.tgz file folder.
