I am having the same issue, as I run:
/riva_quickstart_v2.3.0# bash riva_start.sh
…then:
/riva_quickstart_v2.3.0# docker logs riva-speech
I0818 17:06:19.992784 105 model_repository_manager.cc:1132] successfully unloaded ‘citrinet-1024-en-US-asr-offline-ctc-decoder-cpu-offline’ version 1
Riva waiting for Triton server to load all models…retrying in 1 second
I0818 17:06:20.434286 105 server.cc:267] Timeout 29: Found 0 live models and 0 in-flight non-inference requests
error: creating server: Internal - failed to load all models
W0818 17:06:20.453564 105 metrics.cc:401] Unable to get power limit for GPU 0. Status:Success, value:0.000000
W0818 17:06:20.453699 105 metrics.cc:419] Unable to get power usage for GPU 0. Status:Success, value:0.000000
W0818 17:06:20.453771 105 metrics.cc:443] Unable to get energy consumption for GPU 0. Status:Success, value:0
W0818 17:06:21.453974 105 metrics.cc:401] Unable to get power limit for GPU 0. Status:Success, value:0.000000
W0818 17:06:21.454103 105 metrics.cc:419] Unable to get power usage for GPU 0. Status:Success, value:0.000000
W0818 17:06:21.454173 105 metrics.cc:443] Unable to get energy consumption for GPU 0. Status:Success, value:0
Triton server died before reaching ready state. Terminating Riva startup.
Check Triton logs with: docker logs
/opt/riva/bin/start-riva: line 1: kill: (105) - No such process
My config.sh:
# Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# Architecture of target platform. Supported architectures: amd64, arm64
riva_target_arch="amd64"
# Legacy arm64 platform to be enabled. Supported legacy platforms: xavier
riva_arm64_legacy_platform=""
# Enable or Disable Riva Services
service_enabled_asr=true
service_enabled_nlp=false
service_enabled_tts=false
# Enable Riva Enterprise
# If enrolled in Enterprise, enable Riva Enterprise by setting configuration
# here. You must explicitly acknowledge you have read and agree to the EULA.
# RIVA_API_KEY=<ngc api key>
# RIVA_API_NGC_ORG=<ngc organization>
# RIVA_EULA=accept
# Language code to fetch models of a specify language
# Currently only ASR supports languages other than English
# Supported language codes: en-US, de-DE, es-US, ru-RU, zh-CN, hi-IN
# for any language other than English, set service_enabled_nlp and service_enabled_tts to False
# for multiple languages enter space separated language codes.
language_code=("en-US")
# Specify one or more GPUs to use
# specifying more than one GPU is currently an experimental feature, and may result in undefined behaviours.
gpus_to_use="device=0"
# Specify the encryption key to use to deploy models
MODEL_DEPLOY_KEY="tlt_encode"
# Locations to use for storing models artifacts
# If an absolute path is specified, the data will be written to that location
# Otherwise, a docker volume will be used (default).
# riva_init.sh will create a `rmir` and `models` directory in the volume or
# path specified.
# RMIR ($riva_model_loc/rmir)
# Riva uses an intermediate representation (RMIR) for models
# that are ready to deploy but not yet fully optimized for deployment. Pretrained
# versions can be obtained from NGC (by specifying NGC models below) and will be
# downloaded to $riva_model_loc/rmir by `riva_init.sh`
# Custom models produced by NeMo or TLT and prepared using riva-build
# may also be copied manually to this location $(riva_model_loc/rmir).
# Models ($riva_model_loc/models)
# During the riva_init process, the RMIR files in $riva_model_loc/rmir
# are inspected and optimized for deployment. The optimized versions are
# stored in $riva_model_loc/models. The riva server exclusively uses these
# optimized versions.
riva_model_loc="riva-model-repo"
if [[ $riva_target_arch == "arm64" ]]; then
riva_model_loc="`pwd`/model_repository"
fi
# The default RMIRs are downloaded from NGC by default in the above $riva_rmir_loc directory
# If you'd like to skip the download from NGC and use the existing RMIRs in the $riva_rmir_loc
# then set the below $use_existing_rmirs flag to true. You can also deploy your set of custom
# RMIRs by keeping them in the riva_rmir_loc dir and use this quickstart script with the
# below flag to deploy them all together.
use_existing_rmirs=false
# Ports to expose for Riva services
riva_speech_api_port="50051"
# NGC orgs
riva_ngc_org="nvidia"
riva_ngc_team="riva"
riva_ngc_image_version="2.3.0"
riva_ngc_model_version="2.3.0"
# Pre-built models listed below will be downloaded from NGC. If models already exist in $riva-rmir
# then models can be commented out to skip download from NGC
########## ASR MODELS ##########
models_asr=()
### Citrinet-1024 models
for lang_code in ${language_code[@]}; do
modified_lang_code="${lang_code/-/_}"
modified_lang_code=${modified_lang_code,,}
models_asr+=(
### Citrinet-1024 Streaming w/ CPU decoder, best latency configuration
"${riva_ngc_org}/${riva_ngc_team}/models_asr_citrinet_1024_${modified_lang_code}_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
else
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_asr_citrinet_1024_${modified_lang_code}_str:${riva_ngc_model_version}"
### Citrinet-1024 Streaming w/ CPU decoder, best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_citrinet_1024_${modified_lang_code}_str_thr:${riva_ngc_model_version}"
### Citrinet-1024 Offline w/ CPU decoder,
"${riva_ngc_org}/${riva_ngc_team}/rmir_asr_citrinet_1024_${modified_lang_code}_ofl:${riva_ngc_model_version}"
fi
### Punctuation model
if [[ "${lang_code}" == "en-US" || "${lang_code}" == "de-DE" || "${lang_code}" == "es-US" || "${lang_code}" == "zh-CN" ]]; then
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/models_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
else
models_asr+=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_${modified_lang_code}:${riva_ngc_model_version}"
fi
fi
done
#Other ASR models
models_asr+=(
### Conformer acoustic model, CPU decoder, streaming best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_conformer_en_us_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### German Conformer acoustic model, CPU decoder, streaming best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_conformer_de_de_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### Spanish Conformer acoustic model, CPU decoder, streaming best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_conformer_es_us_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### Hindi Conformer acoustic model, CPU decoder, streaming best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_conformer_hi_in_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### Russian Conformer acoustic model, CPU decoder, streaming best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_conformer_ru_ru_str:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### Citrinet-256 Streaming w/ CPU decoder, best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/models_asr_citrinet_256_en_us_streaming:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
else
models_asr+=(
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_en_us_str:${riva_ngc_model_version}"
### Conformer acoustic model, CPU decoder, streaming best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_en_us_str_thr:${riva_ngc_model_version}"
### Conformer acoustic model, CPU decoder, offline configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_en_us_ofl:${riva_ngc_model_version}"
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_de_de_str:${riva_ngc_model_version}"
### German Conformer acoustic model, CPU decoder, streaming best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_de_de_str_thr:${riva_ngc_model_version}"
### German Conformer acoustic model, CPU decoder, offline configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_de_de_ofl:${riva_ngc_model_version}"
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_es_us_str:${riva_ngc_model_version}"
### Spanish Conformer acoustic model, CPU decoder, streaming best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_es_us_str_thr:${riva_ngc_model_version}"
### Spanish Conformer acoustic model, CPU decoder, offline configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_es_us_ofl:${riva_ngc_model_version}"
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_hi_in_str:${riva_ngc_model_version}"
### Hindi Conformer acoustic model, CPU decoder, streaming best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_hi_in_str_thr:${riva_ngc_model_version}"
### Hindi Conformer acoustic model, CPU decoder, offline configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_hi_in_ofl:${riva_ngc_model_version}"
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_ru_ru_str:${riva_ngc_model_version}"
### Russian Conformer acoustic model, CPU decoder, streaming best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_ru_ru_str_thr:${riva_ngc_model_version}"
### Russian Conformer acoustic model, CPU decoder, offline configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_conformer_ru_ru_ofl:${riva_ngc_model_version}"
### Jasper Streaming w/ CPU decoder, best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_str:${riva_ngc_model_version}"
### Jasper Streaming w/ CPU decoder, best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_str_thr:${riva_ngc_model_version}"
### Jasper Offline w/ CPU decoder
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_ofl:${riva_ngc_model_version}"
### Quarztnet Streaming w/ CPU decoder, best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_quartznet_en_us_str:${riva_ngc_model_version}"
### Quarztnet Streaming w/ CPU decoder, best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_quartznet_en_us_str_thr:${riva_ngc_model_version}"
### Quarztnet Offline w/ CPU decoder
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_quartznet_en_us_ofl:${riva_ngc_model_version}"
### Jasper Streaming w/ GPU decoder, best latency configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_str_gpu_decoder:${riva_ngc_model_version}"
### Jasper Streaming w/ GPU decoder, best throughput configuration
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_str_thr_gpu_decoder:${riva_ngc_model_version}"
### Jasper Offline w/ GPU decoder
# "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_jasper_en_us_ofl_gpu_decoder:${riva_ngc_model_version}"
fi
########## NLP MODELS ##########
models_nlp=(
### BERT Base Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
"${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_bert_base:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
### DistilBERT Intent Slot model for misty domain fine-tuned on weather, smalltalk/personality, poi/map datasets.
# "${riva_ngc_org}/${riva_ngc_team}/models_nlp_intent_slot_misty_distilbert:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
else
models_nlp=(
### Bert base Punctuation model
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base_en_us:${riva_ngc_model_version}"
### BERT base Named Entity Recognition model fine-tuned on GMB dataset with class labels LOC, PER, ORG etc.
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_named_entity_recognition_bert_base:${riva_ngc_model_version}"
### BERT Base Intent Slot model fine-tuned on weather dataset.
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_intent_slot_bert_base:${riva_ngc_model_version}"
### BERT Base Question Answering model fine-tuned on Squad v2.
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_bert_base:${riva_ngc_model_version}"
### Megatron345M Question Answering model fine-tuned on Squad v2.
# "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_question_answering_megatron:${riva_ngc_model_version}"
### Bert base Text Classification model fine-tuned on 4class (weather, meteorology, personality, nomatch) domain model.
"${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_text_classification_bert_base:${riva_ngc_model_version}"
fi
########## TTS MODELS ##########
models_tts=(
"${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us_female_1:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
# "${riva_ngc_org}/${riva_ngc_team}/models_tts_fastpitch_hifigan_en_us_male_1:${riva_ngc_model_version}-${riva_target_arch}${riva_arm64_legacy_platform}"
else
models_tts=(
"${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us_female_1:${riva_ngc_model_version}"
# "${riva_ngc_org}/${riva_ngc_team}/rmir_tts_fastpitch_hifigan_en_us_male_1:${riva_ngc_model_version}"
fi
NGC_TARGET=${riva_ngc_org}
if [[ ! -z ${riva_ngc_team} ]]; then
NGC_TARGET="${NGC_TARGET}/${riva_ngc_team}"
else
team="\"\""
fi
# Specify paths to SSL Key and Certificate files to use TLS/SSL Credentials for a secured connection.
# If either are empty, an insecure connection will be used.
# Stored within container at /ssl/servert.crt and /ssl/server.key
# Optional, one can also specify a root certificate, stored within container at /ssl/root_server.crt
ssl_server_cert=""
ssl_server_key=""
ssl_root_cert=""
# define docker images required to run Riva
image_client="nvcr.io/${NGC_TARGET}/riva-speech-client:${riva_ngc_image_version}"
image_speech_api="nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}-server"
# define docker images required to setup Riva
image_init_speech="nvcr.io/${NGC_TARGET}/riva-speech:${riva_ngc_image_version}-servicemaker"
# daemon names
riva_daemon_speech="riva-speech"
if [[ $riva_target_arch != "arm64" ]]; then
riva_daemon_client="riva-client"
fi
As other posts suggested, I ran clean-up:
bash riva_clean.sh
results via docker logs riva-speech:
error: creating server: Invalid argument - --model-repository must be specified
…as follows:
Environment Details:
Ubuntu 22.04.1 LTS
NVIDIA Driver Version: 510.73.08 (GPU A100)
CUDA Version: 11.6
Docker: 20.10.17
Any thoughts?
Thank you.
