Trouble Adding Missing Drivers to Jetson Orin NX 16GB (Kernel 5.15.136-tegra)
I flashed a Jetson Orin NX 16GB using Nvidia SDK Manager. The installation through JetPack 6.0 (rev. 1) provided Ubuntu 22.04 and Kernel 5.15.136-tegra.
However, the board doesn’t recognize some of the peripherals, which led me to inspect the drivers more closely. Some necessary drivers, like qmi_wwan, iwlwifi, and mt7601u, are absent in /lib/modules/5.15.136-tegra.
As an alternative, I decided to build the modules on my laptop, following the Nvidia Kernel Customization documentation (Kernel Customization — Jetson Linux Developer Guide documentation), ensuring to modify “make ARCH=arm64 O=$TEGRA_KERNEL_OUT menuconfig” to add the modules of interest. (1)
At “JetPack_6.0_Linux_JETSON_ORIN_NX_TARGETS” used previously to flash, there were no source files. Using “Jetson Linux 36.3”, the version of “kernel_src.tbz2” extracted from “public_sources.tbz2” at “/public_sources/Linux_for_Tegra/source_downloaded” was “kernel-jammy-src”, while previous versions (Jetson Linux Archive | NVIDIA Developer) led me to kernel-5.10. Thus, it seemed more appropriate to proceed with the 5.10 version. (2)
I built the modules on my laptop
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install INSTALL_MOD_PATH=$PWD/modules
and copied the “.ko” files to their respective folders at “/lib/modules/5.15.136-tegra” on the Orin board. Afterwards:
$ file qmi_wwan
> qmi_wwan.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=87d899d5bc901656f250110bfff62e38ddad715e, with debug_info, not stripped
$ sudo depmod -a
$ sudo modprobe qmi_wwan
> modprobe: ERROR: could not insert 'qmi_wwan': Exec format error
This error suggests an incompatibility between the module and the current kernel version, what makes sense since 5.15 != 5.10.
  • Is this the proper solution, or is there a more straightforward way to install only specific modules?
  • Is it necessary to use source files described as 5.15.136-tegra or can I proceed with a more generic version (maybe a 5.15)? Where can I find those?
I’m a beginner, please pardon any obvious mistakes.
Thanks in advance.
I’m not sure how you came up with this solution, but of course you need to use 5.15, which is the kernel-jammy-src.
That Exec format error exactly means the kernel version between your module and kernel image is imcompatible.
It’s the 5.15.136 that really matters.
-tegra is just a suffix that we use on kernels for L4T, which can be configured with LOCALVERSION=tegra during building.
Thank you @DaveYYY for the prompt reply! Things worked out using “kernel-jammy-src” and “defconfig” adding “LOCALVERSION=-tegra”.
In case someone comes across the same issue, here’s how I proceeded:
On Ubuntu-Laptop
aarch64-linux-gnu-gcc --version
aarch64-linux-gnu-ld --version
export CROSS_COMPILE=/usr/bin/aarch64-linux-gnu-
export ARCH=arm64
tar -xjf public_sources.tbz2 -C ~/nvidia/kernel_sources
tar -xjf kernel_src.tbz2 -C ~/nvidia/kernel_sources
cd ~/nvidia/kernel_sources/kernel/kernel-jammy-src
kernel-jammy-src/arch/arm64/configs$ ls
>  defconfig
    tegra_prod_defconfig
    defconfig_debug.config
    tegra_recovery_chain_defconfig
make ARCH=arm64 LOCALVERSION=-tegra defconfig
make ARCH=arm64 LOCALVERSION=-tegra menuconfig
    <add modules>
make ARCH=arm64 LOCALVERSION=-tegra modules -j$(nproc)
make ARCH=arm64 LOCALVERSION=-tegra modules_install INSTALL_MOD_PATH=$PWD/modules
On Jetson Orin:
sudo depmod -a $(uname -r)
sudo modprobe <mod_name>
