We are attempting to install VisionWorks on Windows as described in the link named “VisionWorks 1.0 for Windows README” on this page: https://developer.nvidia.com/embedded/visionworks
Our problem is:
We are unable to build the files.
According to the README document, VisionWorks is compatible with Windows with the following configuration:
OS : Windows 8 x64
OpenCV : public OpenCV 2.4.12
CUDA : NVIDIA CUDA 7.0
We are using exactly this same configuration with the following variables as described in the README (with our specific PC’s paths, which we have set these as environment variables with the following values):
[CUDA_VERSION] : 7.0
[CUDA_INSTALL_DIR] : C:\cuda\v7
[OpenCV_INSTALL_DIR] : C:\opencv
[OpenCV_VERSION] : 2412
[VisionWorks_VERSION] : 1.0
[VisionWorks_INSTALL_DIR] : C:\cuda\VisionWorks
[SAMPLES_BUILD_DIR] : C:\cuda\VisionWorks\SAMPLES_BUILD_DIR
We are using Visual Studio 2013 Professional 64-bit.
We have followed the directions in the README as described below and as seen in the images at end of post:
Step 1:
Copy samples from [VisionWorks_INSTALL_DIR]\share\visionworks\sources to a directory with write access [SAMPLES_BUILD_DIR].
Step 2:
Open Visual Studio’s Developer Command Prompt - VS2013 x64 Native Tools
Command Prompt.
Step 3:
Go to the [SAMPLES_BUILD_DIR]:
> cd [SAMPLES_BUILD_DIR]
Step 4:
Edit the config.nmake file to insert correct paths for all prerequisite installation directory information.
# Dependency locations
CUDA_DIR = [CUDA_INSTALL_DIR]
OPENCV_DIR = [OpenCV_INSTALL_DIR]\build
OpenCV_VERSION = [OpenCV_VERSION]
VISIONWORKS_DIR = [VisionWorks_INSTALL_DIR]
# Debug build?
dbg = 0
Step 5:
Build samples using nmake
> nmake
But when we execute the nmake command we get the following error:
C:\cuda\VisionWorks\SAMPLES_BUILD_DIR> nmake
Microsoft ® Program Maintenance Utility Version 12.00.21005.1 Copyright © Microsoft Corporation. All rights reserved.
cd nvxio && “C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\BIN\ amd64\nmake.exe” / /nologo build if NOT EXIST “obj\release” mkdir “obj\release” cl /EHsc /O2 /MD /nologo “-DVISIONWORKS_DIR=“C:/cuda/VisionWorks”” -D USE_GUI=1 -DUSE_GLFW=1 -I./include -I./shaders -I…/3rdparty/opengl -I…/3rdpa rty/freetype/include -I…/3rdparty/glfw3/include -I./src -DUSE_OPENCV=1 -I “C:\c uda\v7\include” -I “C:\opencv\include” -I “C:\cuda\VisionWorks\include” -I “…\3 rdparty\eigen” /Fo"obj\release" /c src\Application.cpp src\ArgumentParser.cpp src\ConfigParser.cpp src\OptionHandler.cpp src\Utility.cpp Application.cpp c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio<b>OptionHandler.hpp(109) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce template argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(118) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(127) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(136) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ ArgumentParser.cpp c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(109) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(118) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(127) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(136) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ ConfigParser.cpp ./include\NVXIO/OptionHandler.hpp(109) : error C2783: ‘nvxio::Range nvxio::ra nges::all(void)’ : could not deduce template argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ ./include\NVXIO/OptionHandler.hpp(118) : error C2783: ‘nvxio::Range nvxio::ra nges::all(void)’ : could not deduce template argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ ./include\NVXIO/OptionHandler.hpp(127) : error C2783: ‘nvxio::Range nvxio::ra nges::all(void)’ : could not deduce template argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ ./include\NVXIO/OptionHandler.hpp(136) : error C2783: ‘nvxio::Range nvxio::ra nges::all(void)’ : could not deduce template argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ OptionHandler.cpp c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(109) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(118) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(127) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\OptionHandler.hpp(136) : error C2783: ‘nvxio::Range nvxio::ranges::all(void)’ : could not deduce te mplate argument for ‘T’ c:\cuda\visionworks\samples_build_dir\nvxio\include\nvxio\Range.hpp(163) : see declaration of ‘nvxio::ranges::all’ Utility.cpp Generating Code… NMAKE : fatal error U1077: ‘“C:\Program Files (x86)\Microsoft Visual Studio 12.0 \VC\BIN\amd64\cl.EXE”’ : return code ‘0x2’ Stop. NMAKE : fatal error U1077: ‘cd’ : return code ‘0x2’ Stop.
Here are a set of images showing the steps described above:
http://i.stack.imgur.com/cwx8S.png
