I’m having great difficulties compiling a project where I am trying to use dynamic parallelism.
I have a K20C card and have the project set up to build for compute capability 3.5
In NSight Eclipse under the project settings I have selected to link with -lcudadevrt
I also have select to compile with the -fPIC
Here is the build command and output I initially got on the file causing trouble(the one where I am using dynamic parallelism):
Building file: …/src/PCG_Kernels.cu
Invoking: NVCC Compiler
nvcc -G -g -O0 -Xcompiler -fPIC -gencode arch=compute_35,code=sm_35 -odir “src” -M -o “src/PCG_Kernels.d” “…/src/PCG_Kernels.cu”
nvcc --compile -G -O0 -Xcompiler -fPIC -g -gencode arch=compute_35,code=compute_35 -gencode arch=compute_35,code=sm_35 -x cu -o “src/PCG_Kernels.o” “…/src/PCG_Kernels.cu”
ptxas fatal : Unresolved extern function ‘cudaGetParameterBuffer’
make: *** [src/PCG_Kernels.o] Error 255
To fix this I opened the file specific settings and modified nvcc command to be invoked like this: nvcc -dc -gencode arch=compute_35,code=sm_35
This changes the build command for this file to be:
nvcc -dc -gencode arch=compute_35,code=compute_35 -G -g -O0 -Xcompiler -fPIC “src/PCG_Kernels.o” “…/src/PCG_Kernels.cu”
Finished building: …/src/PCG_Kernels.cu
But then the linker stage has some issues!
Building target: libIPM_Dynamic
Invoking: NVCC Linker
nvcc -shared -link -o “libIPM_Dynamic” ./src/Main.o ./src/Manager.o ./src/Matrix.o ./src/PCG.o ./src/PCG_Kernels.o ./src/Vector.o ./src/matlabInterface.o -lpthread -lcudadevrt -lhdf5 -lz -lmatio
g++: ./src/PCG_Kernels.o: No such file or directory
I’ve spent about 3 hours trying to build this – I must be missing something, any ideas?
