I’m experimenting with QuantLib on an Ubuntu system with NVidia HPC SDK installed. The code does not have any ACC-pragmas, only the OpenMP ones.
I configure it using the below cmake-command:
cmake .. -DCMAKE_CXX_COMPILER=nvc++ -DQL_USE_PCH=OFF -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_STANDARD=17 -DCMAKE_CXX_EXTENSIONS=OFF -DCMAKE_CXX_FLAGS="-D BOOST_ENABLE_ASSERT_HANDLER -Xcompiler -march=native -O3 -pipe -std=c++17" -DQL_ENABLE_SESSIONS=ON -DQL_ENABLE_PARALLEL_UNIT_TEST_RUNNER=ON -DQL_USE_STD_CLASSES=ON -DQL_ENABLE_OPENMP=ON
The build succeeds, but there are multiple failures of the bundled self-tests. Invoking the test-suit/quantlib-test-suite executable reports numerous errors with various computed figures not matching the expected values. Many tests succeed, but about 80 fail. For example:
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 0 (Homogeneous student with step integration on [0 , 0.03]): 5084.62 vs. 1713
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 1 (Inhomogeneous student with midp integration on [0.03 , 0.06]): 0 vs. 359
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 1 (Inhomogeneous student with step integration on [0.03 , 0.06]): 0 vs. 359
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 1 (Homogeneous student with midp integration on [0.03 , 0.06]): 0 vs. 359
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 1 (Homogeneous student with step integration on [0.03 , 0.06]): 0 vs. 359
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 2 (Inhomogeneous student with midp integration on [0.06 , 0.1]): 0 vs. 136
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 2 (Inhomogeneous student with step integration on [0.06 , 0.1]): 0 vs. 136
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 2 (Homogeneous student with midp integration on [0.06 , 0.1]): 0 vs. 136
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 2 (Homogeneous student with step integration on [0.06 , 0.1]): 0 vs. 136
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 3 (Inhomogeneous student with midp integration on [0.1 , 1]): 0 vs. 9
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 3 (Inhomogeneous student with step integration on [0.1 , 1]): 0 vs. 9
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 3 (Homogeneous student with midp integration on [0.1 , 1]): 0 vs. 9
/workspace/QuantLib-1.41/test-suite/cdo.cpp(90): error: in "QuantLibTests/CdoTests/testHW<QuantLibTests__CdoTests__dataSetFive>": case 4 3 (Homogeneous student with step integration on [0.1 , 1]): 0 vs. 9
The QuantLib project are quite good about maintaining the self-tests, and those succeed on the same system, when built with g++ versions 11 and 12, for example. I’ve also successfully built – and tested – this library on RedHat using g++ 14, and on FreeBSD using clang.
What is nvc++ doing, that’s causing the failures – and why, considering the software is not using any ACC-pragmas?
The nvc++ here is of version 25.11-0…
