I’m trying to follow along with the instruction to compile the vision works examples located in the VisionWorks Toolkit Reference -> Linux: Building and Running Samples and Demos.
I’m running into problem compiling the feature_tracker demo for my Jetson TX1 on a x86 machine. I appear to be missing the libglfw library. The compiler output is
x86-ubuntu:~/VisionWorks-1.2-Samples/demos/feature_tracker$ make
aarch64-linux-gnu-g++ -Wl,--allow-shlib-undefined -pthread -Wl,-rpath=/mnt/jetson/usr/local/cuda-7.0/lib -O3 -DNDEBUG -std=c++0x -o ../../bin/aarch64/linux/release/nvx_demo_feature_tracker obj/release/feature_tracker.o obj/release/main_feature_tracker.o ../../libs/aarch64/linux/release/libnvxio.a -L"/mnt/jetson/usr/lib" ../../libs/aarch64/linux/release/libnvxio.a -L/mnt/jetson/usr/lib/aarch64-linux-gnu -lfreetype ../../3rdparty/glfw3/libs/libglfw3.a -L/mnt/jetson/usr/lib/aarch64-linux-gnu -lGL -L/mnt/jetson/usr/lib/aarch64-linux-gnu -lXrandr -lXi -lXxf86vm -lX11 -L/mnt/jetson/usr/lib/aarch64-linux-gnu -lgstpbutils-1.0 -lgstapp-1.0 -lgstbase-1.0 -lgstreamer-1.0 -lgobject-2.0 -lglib-2.0 -L/mnt/jetson/usr/local/cuda-7.0/lib -lcudart -L/mnt/jetson/usr/lib -L/mnt/jetson/usr/local/cuda-7.0/lib -lvisionworks -lcudart
/usr/lib/gcc-cross/aarch64-linux-gnu/4.8/../../../../aarch64-linux-gnu/bin/ld: cannot find -lfreetype
/usr/lib/gcc-cross/aarch64-linux-gnu/4.8/../../../../aarch64-linux-gnu/bin/ld: ../../3rdparty/glfw3/libs/libglfw3.a(context.c.o): Relocations in generic ELF (EM: 62)
../../3rdparty/glfw3/libs/libglfw3.a: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
make: *** [../../bin/aarch64/linux/release/nvx_demo_feature_tracker] Error 1
My configuration is (with /mnt/jetson mounted with sudo sshfs -o allow_other ubuntu@jetsontxip:/ /mnt/jetson):
x86-ubuntu:~/VisionWorks-1.2-Samples/demos/feature_tracker$ export | grep aarch
declare -x AR="aarch64-linux-gnu-ar"
declare -x ARCH="aarch64"
declare -x CC="aarch64-linux-gnu-gcc"
declare -x CPP="aarch64-linux-gnu-cpp"
declare -x CROSS_COMPILE="aarch64-linux-gnu-"
declare -x CXX="aarch64-linux-gnu-g++"
declare -x LD="aarch64-linux-gnu-ld"
declare -x OS_ARCH="aarch64"
declare -x PKG_CONFIG_PATH="/mnt/jetson/usr/lib/aarch64-linux-gnu/pkgconfig:/mnt/jetson/usr/lib/pkgconfig"
I have also copied the /mnt/jetson/usr/lib/arm-linux-gnueabihf/pkgconfig/ files
to /mnt/jetson/usr/lib/aarch64-linux-gnu/pkgconfig/ folder because they were missing. And I modified them to point to the /mnt/jetson/usr/lib/aarch64-linux-gnu/ path.
libglfw is missing from my /mnt/jetson/usr/lib/aarch64-linux-gnu/
folder and I have not been able to find an aarch64 package for libglfw. I’m going to try to cross-compile glfw, but I’m not having any success.
Thanks for your help
