We have a custom camera card with two TP2855 analog video decoders, each supporting four channels. I’m using a driver provided by Techpoint and it works fine for one chip / four cameras. But while four cameras works I’m having trouble getting the CSI side of the driver to work when I try to use both chips / eight cameras. I think the problem’s related to my device tree settings for “vi” and “nvcsi”.
With eight channels set up when I try to read video from any video input I get these console errors and I receive no video:
[14696.047610] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14696.255589] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14696.262661] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00002000
[14696.270638] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00002000
[14696.483606] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14696.691557] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14696.698508] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000040
[14696.706488] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000040
[14696.919478] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[14696.926127] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000080
[14696.934082] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000080
Here are some relevant parts of the device tree when it’s working correctly with four cameras:
host1x {
vi@15700000 {
num-channels = <4>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
tp2854_vi_in0: endpoint {
status = "okay";
vc-id = <0>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&tp2854_csi_out0>;
...(three more ports)...
nvcsi@150c0000 {
num-channels = <4>;
#size-cells = <0>;
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
tp2854_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&tp2854_out0>;
port@1 {
reg = <1>;
status = "okay";
tp2854_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&tp2854_vi_in0>;
That much works ok. But when I change the num_channels
on vi@15700000
and nvcsi@150c0000
to 8 it doesn’t go so well. I added four additional vi
ports like this:
port@4 {
reg = <0>;
status = "okay";
tp2854_vi_in4: endpoint {
status = "okay";
vc-id = <0>;
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&tp2854_csi_out4>;
This sets the port_index
to 2 which I think is correct. (The codecs are connected to csi0 through csi3).
I also added additional nvcsi
ports like:
channel@4 {
reg = <4>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
tp2854_csi_in4: endpoint@8 {
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&tp2854_out4>;
port@1 {
reg = <1>;
status = "okay";
tp2854_csi_out4: endpoint@9 {
status = "okay";
remote-endpoint = <&tp2854_vi_in4>;
I also changed num_csi_lanes
in tegra-camera-platform
to 8 and added modules:
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <8>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <148500>;
isp_peak_byte_per_pixel = <2>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "tp2854_rear";
position = "rear";
status = "okay";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
devname = "tp2854 2-0046";
status = "okay";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/tp2854_a@44";
...(eight module definitions all up)...
We’re running JetPack 4.6.4/L4T 32.7.4.
Any suggestions where I might be going wrong with my CSI setup?
