I installed the Jetpack multimedia API through the provided instructions (i.e. hook up the TX1 system to another Ubuntu machine and push the updates over SSH).
I am writing a C++ application that uses the camera API. I can include “Argus/Argus.h” and “EGLStream/EGLStream.h” and use all the functionality of these.
But I am having trouble with some of the other libraries, namely those related to Nv Buffers. Specifically, I’m getting an error when I try to include “NvUtils.h” or “nvbuf_utils.h”.
How to I set up my system to compile against these libraries? Are there some additional steps or something?
And a bit more detail I forgot to include. I’m using CMake to generate the makefile. I am providing CMake with the “FindArgus.cmake” and “FindEGL.cmake” files to populate the {ARGUS_INCLUDE_DIRS} and {EGL_INCLUDE_DIRS} fields.
The only copy I can find of “nvbuf_utils.h” or “NvUtils.h” is in “~/tegra-multimedia-api/…” which is the default location that the installer copies them to.
I’d like the application to be portable, so I don’t want to just copy the headers into my application - I need cmake/make/g++ to be able to find the libraries without hardcoding the path.
Thanks for the response DaneLLL, but I don’t see how that is related at all to my question.
I flashed another TX1 to r28.1, and once again, all of the multimedia API were installed to ~/tegra_multimedia_API
Is there a way to get my compiler to find the MMAPI dynamically? For example, if I use CMake, I can get CMake to find the Argus library (but only the Argus library) by including FindArgus.cmake in my cmake include directory.
I want my application to be portable and extensible to future versions, so I don’t want to copy the header files or hardcode any paths. Is this possible?
I am currently trying to integrate some functionality developed using Tegra MMAPI with an existing project built with Cmake and I am running into errors. More specifically, when trying to add some of the classes defined at:
/tegra_multimedia_api/samples/common/classes
Have you used those in your project? If yes, would you mind sharing the modifications you made to CMakeLists.txt to solve your problem?[/s]
