Hi. I’ve been trying to install the PGI 7.0 compiler on a 64-bit Linux machine running RedHat Enterprise Linux 4. I have installed all of the “compatibility libraries” I can find, but I’ve obviously missed something important. I keep getting this message when I try to install PGI:
Note: This Linux installation does not appear to support 32-bit compilation.
The command ‘gcc -m32 hello.c’ where hello.c contains the simple
C program
main(){printf(“hello\n”);}
should produce a 32-bit executable a.out
The command “gcc -m32 hello.c” ends with this:
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
Can someone please tell me what I’m missing? Any help will be very much appreciated.
Thank you very much.
