I have trouble installing the assets for the new contest. I didn’t find any walktrhough on how to do it. What’s the procedure to install the assets manually? I copied them to Nvidia Omniverse/Cache Pat/client/localhost/Nvidia/Samples where the other assets are, but the didnt appear in Nucleus nor in Create, even when I refreshed the directory with the right clik menu option.
Did you download additional Marbles assets from an NVIDIA web page? File might have come as a .zip file?
Did you manually move the entire folder within this zip to your “D:/Nvidia Omniverse/Cache Path/client/localhost/Nvidia/Samples” folder and call that folder “Marbles Machin???” (can not see the full file name)?
Yup, that is exactly what I did. I downloaded the zip, unzipped it and moved it where I found the other assets, thinking Omniverse would find it.
The first time I installed omniverse, the first “Marbles” pack was there from the start. And the tutorial to install the initial Marbles pack shows the same scenario. Couldnt find any info on how to install a Samples or Asset pack manually.
