Trouble using J14
Hello. As the J12 serial THS0 port only has UART1, I’m trying to use J14’s UART2 RXD TXD ports for higher speed. Thing is, I’m unable to get any communication out of it connected to the host PC, despite renaming the serial devices as THS0, THS1 or THS4 in minicom which was then tested in putty. The serial to usb cable used is an adafru.it/954 if that changes anything.
Sorry for the late response, is this still an issue to support?
hello kivyn00b,
may I know what’s the request baudrate here.
you may also check below topics as see-also.
thanks
