Trouble using VPI Conversion NV12_ER -> BGR with DMA id from GStreamer
Hey!
I’m using gstreamer to pull frames from a RTSP stream where the last element in my gstreamer looks like:
GstCaps *capsfilter_caps =
            gst_caps_new_simple("video/x-raw(NVMM)",
                                "format", G_TYPE_STRING, "NV12_ER",
                                NULL);
On a new sample, I extract the dmabuf_id and then pass It to VPI to convert from NV_12ER to BGR
static VPIContext _ctx = NULL;
static VPIStream _stream = NULL;
GstFlowReturn new_sample(GstAppSink *sink, struct App *app)
    GstSample *sample = gst_app_sink_pull_sample(sink);
    if (!sample)
        return GST_FLOW_ERROR;
    GstBuffer *buffer = gst_sample_get_buffer(sample);
    if (!buffer)
    GstMapInfo map;
    if (gst_buffer_map(buffer, &map, GST_MAP_READ))
        int dmabuf_fd;
        ExtractFdFromNvBuffer(map.data, &dmabuf_fd);
        NvBufferParams par;
        NvBufferGetParams(dmabuf_fd, &par);
        printf("DMA %i\n", dmabuf_fd);
        if(!_ctx)
            // Create our context.
            vpiContextCreate(0, &_ctx);
            // Activate it. From now on all created objects will be owned by it.
            vpiContextSetCurrent(_ctx);
            // Create the stream for the given backend.
            vpiStreamCreate(VPI_BACKEND_CUDA, &_stream);
        VPIImage inDmaVpi = NULL;
        vpiImageCreateNvBufferWrapper(dmabuf_fd, NULL, 0 | VPI_EXCLUSIVE_STREAM_ACCESS, &inDmaVpi);
        VPIImage outBgrImage = NULL;
        vpiImageCreate(1280, 720, VPI_IMAGE_FORMAT_BGR8, 0, &outBgrImage);
        int failState = vpiSubmitConvertImageFormat(_stream, VPI_BACKEND_CUDA, inDmaVpi, outBgrImage, NULL);
        printf("STATE: %i\n", failState);
    gst_buffer_unref(buffer);
    return GST_FLOW_OK;
The problem is that vpiSubmitConvertImageFormat keeps returning VPI_ERROR_NOT_IMPLEMENTED. I’ve tried (NV12,NV_12ER,BGRx)->(RGB8/RGBA8/BGR8/BGRA8) and I get the same output.
Is it possible to grab a dmabuf_id from a gstreamer pipeline and use VPI to do color conversions on it? I’ve tested this same code with NvBufferCreate() and it works fine. If not, how do I successfully do this? Grabbing the DmaBuffer data and giving it to VPI to do color conversions.
It looks like you are still using VPI 1.
It’s recommended to use our latest software which should contain VPI 2.1.
Please let us know if the same error also occurs with VPI 2.1.
