Good day all of them! Jtop utilites doesn’t work on my jetson orin nx with jetpack 5.1.1
Hello @cash496,
Hope everything is going great.
Can you provide the output of the following command:
systemctl status jtop.service
And also please run:
journalctl -u jtop.service
best regards,
Andrew
We would suggest upgrade to latest Jetpack 6.2.1 r36.4.4. If you have to stay on 5.1.1, please execute $ sudo tegrastats to get system status.
Hey @cash496,
Quick question.
Do you happen to have some logs on the skipping camera frames issue you are seeing on JP 6.2.1 ?
I want to confirm if it is similar to an issue we have seen before, and see if we could possibly point you in the right direction.
best regards,
Andrew
Get Expert NVIDIA Jetson Support - Proventus Nova
Our problem issue is number 4325898 (nvv4l2decoder). When will this issue be resolved?
