Hi NVIDIA,
after playing with raytracing for a bit i ran into some trouble with the shader binding table.
The first one is that i cannot get shaderRecordNV to work. I specified a hit group SBT stride of 48 for the hitShaderBindingStride parameter in the vkCmdTraceRaysNV call and populated the first 16 bytes of each record with the hit group handles. This works as expected, and correctly selects different shaders for different BLAS based on VkGeometryInstanceNV::instanceOffset in the TLAS. But as soon as i try to access any value in the 32 bytes of application data following the hit group handles, my program just freezes. This only happens if i actually access the memory in the shader (closest hit), and that shader is actually called (if the geometry for the shader that does the access is not hit, the program works).
The GLSL code for the closest hit shader looks like this:
#version 460 core
#extension GL_NV_ray_tracing : require
rayPayloadInNV vec4 payload;
hitAttributeNV vec2 baryCoord;
layout(shaderRecordNV) buffer SR
float test;
void main()
// Does not work
payload = vec4(0.0, 0.5 + test, 0.0, 1.0);
// Does work
// payload = vec4(0.0, 0.5, 0.0, 1.0);
The app works as long as the “+ test” is omitted.
The second is that the sbtRecordStride for the traceNV call in the shader does not work as stated in the spec. This parameter should adjust the way different geometries in BLAS index the SBT. In case each BLAS has only one geometry, this parameter should do nothing. Yet it affects my shader in a strange way. It seems like it is first divided by 16 (the low 4 bit are ignored in all my tests) and is then simply added to the index, not multiplying it with the geometry index (which for my BLAS should be 0). So sbtRecordStride / 16 acts like sbtRecordOffset, which makes no sense.
I hope someone from NVIDIA can help me with this, i can provide traces or source code in private if required.
Spec:
Win 7 x64
RTX 2070
Driver 417.42
LunarG 1.1.92.1
Regards
