I am running the Jetpack 3.3 installer. I intend on doing some development on my host machine using several packages included in the Jetpack SDK including OpenCV, Tensor RT etc…
However, when I run the installer and end up on the ‘components manager’ screen where I can select which packages to install, none of the required packages are available to be installed on my host. I am able to see ‘Tegra Graphics Debugger’, ‘Nvidia System Profiler’, ‘Jetpack Documentation’, and ‘DevTools Documentation’, but no libraries under host.
The ‘target’ components are all there.
Note that I am not currently using a physical TX2 board (I have it but not connected to this computer), not sure if this may be the cause.
Any help would be appreciated.
OS: Ubuntu 18.04 64 bit.
CPU: AMD FX9590
GPU: Nvidia 980GTX ti
