Hi.
I am having an issue where I see some very strange things when registering some ACM devices as a usb gadget on my TX2.
#!/bin/bash -e
modprobe libcomposite
cd /sys/kernel/config/usb_gadget/
mkdir g && cd g
echo 0x1d6b > idVendor # Linux Foundation
echo 0x0104 > idProduct # Multifunction Composite Gadget
echo 0x0100 > bcdDevice # v1.0.0
echo 0x0200 > bcdUSB # USB 2.0
echo 0xEF > bDeviceClass
echo 0x02 > bDeviceSubClass
echo 0x01 > bDeviceProtocol
mkdir -p strings/0x409
echo "deadbeef00115599" > strings/0x409/serialnumber
echo "Something" > strings/0x409/manufacturer
echo "Something" > strings/0x409/product
mkdir -p functions/hid.usb0
echo 1 > functions/hid.usb0/protocol
echo 1 > functions/hid.usb0/subclass
echo 8 > functions/hid.usb0/report_length
mkdir -p functions/acm.usb0
mkdir -p functions/acm.usb1
mkdir -p functions/acm.usb2
mkdir -p functions/acm.usb3
mkdir -p configs/c.1
echo 250 > configs/c.1/MaxPower
ln -s functions/rndis.usb0 configs/c.1/
ln -s functions/hid.usb0 configs/c.1/
ln -s functions/acm.usb0 configs/c.1/
ln -s functions/acm.usb1 configs/c.1/
ln -s functions/acm.usb2 configs/c.1/
ln -s functions/acm.usb3 configs/c.1/
# OS descriptors
echo 1 > os_desc/use
echo 0xcd > os_desc/b_vendor_code
echo MSFT100 > os_desc/qw_sign
echo RNDIS > functions/rndis.usb0/os_desc/interface.rndis/compatible_id
echo 5162001 > functions/rndis.usb0/os_desc/interface.rndis/sub_compatible_id
ln -s configs/c.1 os_desc
udevadm settle -t 5 || :
ls /sys/class/udc/ > UDC
I am seeing some flakiness on my mac when connected to my Jetson through microUSB: If I register 1 or 2 devices, everything works fine (except for the strange group change (see below)), but with 3 or more, my laptop can’t always detect the USB devices registered. It works about 1 in 20 tries, and the cable used seem to make a difference (but it is still flaky).
Sample report from my mac when it doesn’t work:
$ls /dev/cu.*
/dev/cu.Bluetooth-Incoming-Port
$ system_profiler SPUSBDataType
Something:
Product ID: 0x0104
Vendor ID: 0x1d6b (The Linux Foundation)
Version: 1.00
Manufacturer: Something
Location ID: 0x14200000 / 30
Current Available (mA): 500
Extra Operating Current (mA): 0
Sample report when it works:
$ ls /dev/cu.*
/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem1426 /dev/cu.usbmodem142A
/dev/cu.usbmodem1424 /dev/cu.usbmodem1428
Something:
Product ID: 0x0104
Version: 1.00
Location ID: 0x14200000 / 8
Current Required (mA): 250
Note that the currentRequired line is present on the report when it works. I tried changing the maxPower value in the script but that made no difference.
I have tried replacing the mac in question but got the same result (Linux laptops seem to work fine!), I have changed all the cables and rebooted everything after every attempt.
Something interesting is that after running the script, I see the group of the first device change after a few seconds:
nvidia@tegra-ubuntu:~$ sudo setup_usb.sh
nvidia@tegra-ubuntu:~$ ls -l /dev/ttyG*
crw-rw---- 1 root dialout 234, 0 Mar 23 16:36 /dev/ttyGS0
crw-rw---- 1 root dialout 234, 1 Mar 23 16:36 /dev/ttyGS1
crw-rw---- 1 root dialout 234, 2 Mar 23 16:36 /dev/ttyGS2
crw-rw---- 1 root dialout 234, 3 Mar 23 16:36 /dev/ttyGS3
But then, after a few seconds, it changes to
crw--w---- 1 root tty 234, 0 Mar 23 16:36 /dev/ttyGS0
Any ideas on why this is happening or how to debug it?
Thanks a lot.
