Hi, I’ve got many problems:
1- I can’t find a version of cuda 9.2
2- When I install cuda, tensorflow 2.0 doesn’t work.
3- And many command exit with that:
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
cuda-libraries-dev-10-1 : Depends: libcublas-dev (>= 10.1.0.105) but it is not going to be installed
cuda-samples-10-1 : Depends: libcublas-dev (>= 10.1.0.105) but it is not going to be installed
cuda-visual-tools-10-1 : Depends: libcublas-dev (>= 10.1.0.105) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And when I run
>> import tensorflow as tf
It prints
ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
Failed to load the native TensorFlow runtime.
