I have installed a 64bit version of pgi compilers version 11.0. The compilation procedure works well, but when I connect myself in the internet I receive a lot of messages like these:
It is quite frustating because simply I can´t use the internet ever when I have to make use of the compilers and debuggers. Any help would be very much appreciate.
Yes, that is the point. I had alread tried to assert different port numbers to two daemons: lmgrd and pgroupd. I was also concerned to be the firewall the guilty for this freak behaviour. However, I think the problem is the kind of internet connection I have used to. When I use my 3G modem the prompt in shell terminal hangs on. On the other hand as I use cable access everything goes fine. So the problem perhaps is how I access the web.
As asked for you, I disallowed my firewall, and even though the compilers have still failed. I have already sent to you the output from ipconfig/all as requested.
