WARN TRT: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars trt_utils.cpp:254
Could you please share with us more details like complete verbose logs, minimal issue repro model/script and the following environment details,
TensorRT Version : GPU Type : Nvidia Driver Version : CUDA Version : CUDNN Version : Operating System + Version : Python Version (if applicable) : TensorFlow Version (if applicable) : PyTorch Version (if applicable) : Baremetal or Container (if container which image + tag) :
Hi, I have a same erro when i run the demo(TensorRT/cpp) of YOLOX, and this is my environment details: TensorRT Version : 8.5.1.7 GPU Type :RTX 3060 Nvidia Driver Version : 516.94 CUDA Version :v11.7 CUDNN Version :8.5.0.96 Operating System + Version : Windows11 22621.963 Python Version (if applicable) : not used TensorFlow Version (if applicable) : not used PyTorch Version (if applicable) : not used
[12/26/2022-11:29:32] [TRT] [W] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
Loading ONNX file from path …/yolov7/runs/train/yolov7_master3/weights/best.onnx…
Beginning ONNX file parsing
[12/26/2022-11:29:32] [TRT] [W] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[12/26/2022-11:29:32] [TRT] [W] onnx2trt_utils.cpp:403: One or more weights outside the range of INT32 was clamped
Completed parsing of ONNX file
Building an engine from file …/yolov7/runs/train/yolov7_master3/weights/best.onnx; this may take a while…
Completed creating Engine
[12/26/2022-11:31:58] [TRT] [W] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
[12/26/2022-11:31:58] [TRT] [W] The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
I bet you can easily reproduce this by running the yolo sample packed with TensorRT. Most people just ignore this message. I suggest suppressing it if it’s not adding value.
