Description
I am trying to use the TRT Engine Explorer to get insights about my model.
The neccessary JSON file were generated using utils/process_engine.py:
<MODEL_NAME>.(graph.json, metadata.json, profile.json, timing.json)
However, trying to instantiate the EnginePlan object, I am getting the following error:
ValueError Traceback (most recent call last)
Input In [2], in <cell line: 2>()
1 assert engine_name is not None
----> 2 plan = EnginePlan(f'{engine_name}.graph.json', f'{engine_name}.profile.json', f'{engine_name}.metadata.json')
File ~/devel/TensorRT/tools/experimental/trt-engine-explorer/trex/engine_plan.py:103, in EnginePlan.__init__(self, graph_file, profiling_file, profiling_metadata_file, build_metadata_file, name)
99 self.total_runtime = sum(
100 [avg_time for avg_time in self._df["latency.avg_time"]])
102 self.name = name or path_leaf(graph_file)
--> 103 raw_layers, self.bindings = import_graph_file(graph_file)
104 raw_layers = create_layers(self, raw_layers)
106 self._df = None
File ~/devel/TensorRT/tools/experimental/trt-engine-explorer/trex/parser.py:134, in import_graph_file(graph_file)
131 pass
132 return raw_layers
--> 134 raw_layers, bindings = read_graph_file(graph_file)
135 raw_layers = convert_deconv(raw_layers)
136 raw_layers = disambiguate_layer_names(raw_layers)
File ~/devel/TensorRT/tools/experimental/trt-engine-explorer/trex/parser.py:52, in read_graph_file(graph_file)
50 details_msg = "\nMake sure to enable detailed ProfilingVerbosity."
51 details_msg += "\nSee https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#engine-inspector"
---> 52 raise ValueError(err_msg + details_msg)
53 return layers, bindings
ValueError: File engine.trt.graph.json does not conform to the expected JSON format.
Quick look at the parser code tells me that parser expect the list of layers in graph.json to be a list of dictionaries. The file generated by trtexec contains only plain layer names though:
{"Layers": ["Range_1363"
,"Range_1367"
,"Squeeze_454"
,"Conv_455 + Relu_456"
,"MaxPool_457"
Profiling files were generated like this:
$ python3 utils/process_engine.py --profile_engine engine.trt outputs
Profiling the engine:
trtexec --verbose --noDataTransfers --useCudaGraph --separateProfileRun --nvtxMode=verbose --loadEngine=engine.trt --exportTimes=outputs/engine.trt.timing.json --exportProfile=outputs/engine.trt.profile.json --exportLayerInfo=outputs/engine.trt.graph.json --timingCacheFile=./timing.cache
Successfully profiled the engine.
Device info: 1 device(s) found
Device info: generated output file outputs/engine.trt.metadata.json
Artifcats directory: outputs
I would be grateful about any hint here.
Environment
TensorRT Version: 8.2.5
NVIDIA GPU: RTX A6000
NVIDIA Driver Version: 515.65.01
CUDA Version: 11.7
CUDNN Version:
Operating System: Ubuntu 20.04
Python Version (if applicable): 3.8.10
Tensorflow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if so, version): nvcr.io/nvidia/pytorch:22.06-py3
