I have followed the steps described to install TensorRT OSS and deepstream-tlt-apps on my Xavier (TRT 7.0, DeepStream 5.0 and CUDA 10.2) and both the libraries were built successfuly. However when I tried to run the example application for frcnn I get the following error:
Now playing: pgie_frcnn_tlt_config.txt Opening in BLOCKING MODE Opening in BLOCKING MODE 0:00:00.239738191 12739 0x558ded24f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files ERROR: [TRT]: UffParser: UFF buffer empty parseModel: Failed to parse UFF model ERROR: failed to build network since parsing model errors. ERROR: Failed to create network using custom network creation function ERROR: Failed to get cuda engine from custom library API 0:00:01.450726826 12739 0x558ded24f0 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1611> [UID = 1]: build engine file failed Bus error (core dumped)
Thanks for your reply. There seems to be a LFS bandwidth issue associated with the deepsream-tlt-apps repository. I have git-lfs installed and when I try to clone the repo I see the following error:
git clone GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream Cloning into ‘deepstream_tlt_apps’… remote: Enumerating objects: 116, done. remote: Counting objects: 100% (116/116), done. remote: Compressing objects: 100% (90/90), done. remote: Total 116 (delta 35), reused 96 (delta 22), pack-reused 0 Receiving objects: 100% (116/116), 46.99 KiB | 1.27 MiB/s, done. Resolving deltas: 100% (35/35), done. Downloading TRT-OSS/Jetson/TRT7.1/libnvinfer_plugin.so.7.1.3_nano_tx2_xavier_nx (9.1 MB) Error downloading object: TRT-OSS/Jetson/TRT7.1/libnvinfer_plugin.so.7.1.3_nano_tx2_xavier_nx (846691c): Smudge error: Error downloading TRT-OSS/Jetson/TRT7.1/libnvinfer_plugin.so.7.1.3_nano_tx2_xavier_nx (846691ccb0caa16a25d116084da4bf8b9a783130ddd45c16f57cef1f0f7f40e6): batch response: This repository is over its data quota. Account responsible for LFS bandwidth should purchase more data packs to restore access.
Errors logged to /home/dilip/Develop/deepstream_tlt_apps/.git/lfs/logs/20200727T113253.191502438.log Use git lfs logs last to view the log. error: external filter ‘git-lfs filter-process’ failed fatal: TRT-OSS/Jetson/TRT7.1/libnvinfer_plugin.so.7.1.3_nano_tx2_xavier_nx: smudge filter lfs failed warning: Clone succeeded, but checkout failed. You can inspect what was checked out with ‘git status’ and retry the checkout with ‘git checkout -f HEAD’
Even though all the source files are getting cloned the model directories contain the cal.bin files but not the tlt model files.
I believe the UFF buffer empty is also related to the git lfs cloning issue. Since the models were not getting downloaded via git clone I tried downloading the raw model files using wget and curl but it appears they werent successful as it’s a LFS file and whatever model files that were created were incomplete. I had cloned the repository on my Ubuntu PC couple months ago, when I manually copied over the rtlt model file for faster rcnn the deepstream-custom app loaded the file, created the engine and ran successfully.
Yes I did install git lfs per the installation steps for deepstream TLT apps repo. It appears there’s a known issue with this repo and GIT LFS, I had posted an issue on the github repository and got a response there acknowledging the issue and that they’re currently working on it.
