TRT Fails to parse ONNX Model (yolov8 Segmentation)
• Hardware Platform (Jetson / GPU): Jetson Nvidia Xavier NX
• DeepStream Version: 6.0
• TensorRT Version: 8.2.1.8
• NVIDIA GPU Driver Version (valid for GPU only):
Hi
I tried to serialize a yolov8-Segmentation Network but it fails.
I converted the YoloV8 Model using the instructions given from GitHub - marcoslucianops/DeepStream-Yolo-Seg: NVIDIA DeepStream SDK 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 implementation for YOLO-Segmentation models .
When trying to generate the TRT it fails with the following error.
I also like to mention that I used many yoloV8 models for object detection and I never had an issue while serializing.
The issue only occurs when using segmentation model.
nvidia@ubuntu:/etc/stereo_camera/dnn/DeepStream-Yolo-Seg$ deepstream-app -c deepstream_app_config.txt
Using winsys: x11
ERROR: Deserialize engine failed because file path: /etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine open error
0:00:03.498454304  7679   0x7f300022c0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine failed
0:00:03.521018368  7679   0x7f300022c0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine failed, try rebuild
0:00:03.521485568  7679   0x7f300022c0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: Tensor DataType is determined at build time for tensors not marked as input or output.
WARNING: [TRT]: onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
ERROR: [TRT]: ModelImporter.cpp:773: While parsing node number 449 [RoiAlign -> "/1/RoiAlign_output_0"]:
ERROR: [TRT]: ModelImporter.cpp:774: --- Begin node ---
ERROR: [TRT]: ModelImporter.cpp:775: input: "/0/model.22/proto/cv3/act/Mul_output_0"
input: "/1/Reshape_1_output_0"
input: "/1/Gather_1_output_0"
output: "/1/RoiAlign_output_0"
op_type: "RoiAlign"
attribute {
  s: "half_pixel"
  type: STRING
attribute {
  s: "avg"
  type: STRING
attribute {
  i: 320
  type: INT
attribute {
  i: 320
  type: INT
attribute {
  i: 0
  type: INT
attribute {
  f: 0.25
  type: FLOAT
ERROR: [TRT]: ModelImporter.cpp:776: --- End node ---
ERROR: [TRT]: ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4870 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
ERROR: Failed to parse onnx file
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:04.630773120  7679   0x7f300022c0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:04.656896928  7679   0x7f300022c0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:04.657157920  7679   0x7f300022c0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:04.657713088  7679   0x7f300022c0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:04.657768064  7679   0x7f300022c0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /etc/stereo_camera/dnn/DeepStream-Yolo-Seg/config_infer_primary_yoloV8_seg.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:707>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
I also tried running the model with trtexec command.
This also fails with the following error:
[09/28/2023-16:24:31] [I] === Device Information ===
[09/28/2023-16:24:31] [I] Selected Device: Xavier
[09/28/2023-16:24:31] [I] Compute Capability: 7.2
[09/28/2023-16:24:31] [I] SMs: 6
[09/28/2023-16:24:31] [I] Compute Clock Rate: 1.109 GHz
[09/28/2023-16:24:31] [I] Device Global Memory: 7773 MiB
[09/28/2023-16:24:31] [I] Shared Memory per SM: 96 KiB
[09/28/2023-16:24:31] [I] Memory Bus Width: 256 bits (ECC disabled)
[09/28/2023-16:24:31] [I] Memory Clock Rate: 1.109 GHz
[09/28/2023-16:24:31] [I] TensorRT version: 8.2.1
[09/28/2023-16:24:33] [I] [TRT] [MemUsageChange] Init CUDA: CPU +363, GPU +0, now: CPU 381, GPU 3622 (MiB)
[09/28/2023-16:24:34] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 381 MiB, GPU 3622 MiB
[09/28/2023-16:24:34] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 486 MiB, GPU 3727 MiB
[09/28/2023-16:24:34] [I] Start parsing network model
[09/28/2023-16:24:35] [I] [TRT] ----------------------------------------------------------------
[09/28/2023-16:24:35] [I] [TRT] Input filename:   /etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx
[09/28/2023-16:24:35] [I] [TRT] ONNX IR version:  0.0.8
[09/28/2023-16:24:35] [I] [TRT] Opset version:    16
[09/28/2023-16:24:35] [I] [TRT] Producer name:    pytorch
[09/28/2023-16:24:35] [I] [TRT] Producer version: 2.1.2
[09/28/2023-16:24:35] [I] [TRT] Domain:
[09/28/2023-16:24:35] [I] [TRT] Model version:    0
[09/28/2023-16:24:35] [I] [TRT] Doc string:
[09/28/2023-16:24:35] [W] [TRT] onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[09/28/2023-16:24:35] [W] [TRT] Tensor DataType is determined at build time for tensors not marked as input or output.
[09/28/2023-16:24:35] [W] [TRT] onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
[09/28/2023-16:24:35] [I] [TRT] No importer registered for op: RoiAlign. Attempting to import as plugin.
[09/28/2023-16:24:35] [I] [TRT] Searching for plugin: RoiAlign, plugin_version: 1, plugin_namespace:
[09/28/2023-16:24:35] [E] [TRT] ModelImporter.cpp:773: While parsing node number 449 [RoiAlign -> "/1/RoiAlign_output_0"]:
[09/28/2023-16:24:35] [E] [TRT] ModelImporter.cpp:774: --- Begin node ---
[09/28/2023-16:24:35] [E] [TRT] ModelImporter.cpp:775: input: "/0/model.22/proto/cv3/act/Mul_output_0"
op_type: "RoiAlign"
attribute {
  s: "half_pixel"
  type: STRING
attribute {
  s: "avg"
  type: STRING
attribute {
  i: 320
  type: INT
attribute {
  i: 320
  type: INT
attribute {
  i: 0
  type: INT
attribute {
  f: 0.25
  type: FLOAT
[09/28/2023-16:24:35] [E] [TRT] ModelImporter.cpp:776: --- End node ---
[09/28/2023-16:24:35] [E] [TRT] ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4870 In function importFallbackPluginImporter:
[09/28/2023-16:24:35] [E] Failed to parse onnx file
[09/28/2023-16:24:35] [I] Finish parsing network model
[09/28/2023-16:24:35] [E] Parsing model failed
[09/28/2023-16:24:35] [E] Failed to create engine from model.
[09/28/2023-16:24:35] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8201] # ./trtexec --onnx=/etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx
Could you share your onnx model to us?
Sure thing.
I used the basic model from ultralytics and converted it to onnx using the instructions provided by DeepStream-Yolo-Seg/docs/YOLOv8_Seg.md at master · marcoslucianops/DeepStream-Yolo-Seg · GitHub.
Basic model from ultralytics:
https://github.com/ultralytics/assets/releases/download/v0.0.0/yolov8s-seg.pt
ONNX Model:
yolov8s-seg.zip (38.2 MB)
TensorRT 8.2 has been released for a while.
Would you mind giving JetPack 5 a try?
