Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.0.10816
other
Host Machine Version
other
I’m trying to generate trt models on DriveOrin, however I run into a problem:
File "traffic_light_net_trt.py", line 4, in <module>
import torch
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/__init__.py", line 195, in <module>
_load_global_deps()
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/__init__.py", line 148, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libmpi_cxx.so.20: cannot open shared object file: No such file or directory
I have tried use this post: https://forums.developer.nvidia.com/t/pytorch-for-jetson/72048
It didn’t work as I’m failing to install necessary info.
As far as I know I have to generate a TRT model on a hardware I will run that model later on.
I want to generate the trt model on my host be able to run them on DriveOrin. Is it possible?
Thanks,
